Forums › General Discussion › Rudder Details
Viewing 11 reply threads
    • #68935
      Miss Kathleen
      Hi All,
      We had a big 70+ knot storm pass through Auckland two weeks ago. Unfortunately a large 23 ton ferro yacht in the berth alongside broke her bow mooring and rubbed away parts of the cap rail and rubbing strake.
      It is now in the hands of insurance!
      As a result Miss Kathleen will be out of the water for a while whilst repairs are undertaken.
      Now, I was wondering, especially having seen another P424 with a larger than normal rudder, if I could enlarge my rudder.
      The plan is to add a piece that extends past the current the depth of the rudder, and includes a piece forward of the rudder shaft. The thought being that this will enhance her steering, especially in reverse (I do not have a bow thruster)
      Question – has anyone ventured into the internals of the rudder. Is it solid wood with glass, or a stainless frame?
      Any ideas / comments / opinions would be appreciated.
      In the end the cost may be prohibitive, but it would be nice to know.
      Dennis
    • #81143
      Hi Dennis,
      I’m not sure how you would extend the rudder forward without major
      modifications to the skeg. Since the skeg takes a lot of the stress at the
      lower end of the rudder I’m not sure it’s such a great idea.
      If I were to extend the rudder, it would be to elongate it by 4 to 6 inches
      using a foam core and 3 layers of biaxial glass, each layer extending over
      the other towards the front of the rudder. It’s a job that can be done
      without removing the rudder from the boat.
      Things that will change are the amount of wheel movement for a given turn
      and on the downside, when backing, the force on the rudder and steering
      mechanism is increased so that releasing the wheel will result in a rather
      quick and dramatic slam to the stops one way or another.
      The real issue with backing is that the prop is so far from the rudder and
      there’s a skeg in the way so flow over the rudder is from motion through
      the water only rather than from the prop and motion. If you can get the
      boat going at a couple of knots in astern it steers pretty ok because
      there’s enough flow.
      On another tack, I plan on through bolting pad eyes on the upper aft corner
      of the rudder for emergency steering.
      On Tue, Jun 24, 2014 at 2:10 AM, Miss Kathleen via maillist <
      > wrote:
      Hi All,
      bow thruster)
      Dennis
    • #81151
      Dennis,
      I agree with Bob on rudder extension. In addition,
      building it deeper will expose it to damage when
      grounding, especially if you build it down beyond the
      skeg. Our boats steer in reverse once they get moving.
      At first, though, I tend to throttle gently in reverse,
      building up sternway gradually, and compensating for
      the tendency of the stern to kick to starboard by
      cocking the rudder halfway to port.
      Bob, pad eyes on the rudder for emergency steering is a
      prudent precaution, but the hardware will produce
      unnecessary drag. An alternative way to prepare a
      rudder to accept emergency steering lines is by
      drilling a 1″ hole through it, in Silverheels’ case
      2-to-3″ diagonally inward from the lower aft corner.
      (You can just see it in the attached photo. It seemed
      to me at the time that lines from that lower aft corner
      will have a clearer run to the primary winches than
      from the upper corner, albeit at a sharper angle.) Seal
      the raw surface of the tubular hole with smoothed
      epoxy, taking care to round the edges at each end, and
      anti-foul it when you paint the bottom. It would be an
      unusual circumstance that would call for its use – the
      steering system broken but the rudder OK and moving
      freely – but it’s a precaution that does no harm.
    • #81144
      I agree with the hole thing and have waffled over that or pad eyes, which
      is why I haven’t done either.
      The hole is usually at the top because the angle of pull on the rudder is
      more directly in a steering direction than when at the bottom of the
      rudder.
      phone.
      On Jun 24, 2014 8:36 AM, “Silverheels via maillist”
      wrote:
      Dennis,
    • #81145
      Re holes and padeyes:
      The P-424 has a 1.5″ solid rudder shaft. It’s reasonable to assume that there are some horizontal bars welded on it inside the rudder.
      The biggest risk is that water gets inside the rudder, and corrodes the welds and causes the rudder shaft to shear loose from the rudder.
      I’d be careful about drilling holes in the rudder that will be under water.
    • #81146
      My untested approach is to use the emergency tiller, but attach block and
      tackle to the tiller. Moving that rudder without the mechanical advantage
      of the wheel is going to be a bitch. If my 4:1 purchase on the tiller is
      insufficient, then I would run the line to the sheet winches. Hope none
      of us gets to find out if any of these approaches will work.
      http://www.svsarah.com/Sarah/Images/Emergency%20Tiller%205.JPG
      Sarah’s Blog
      On Tue, Jun 24, 2014 at 9:03 AM, quent via maillist <
    • #81147
      A good point, Quent. That’s why I over-drilled the hole
      and then sealed the wall with plenty of epoxy. I’m
      pretty sure it’s 100% waterproof.
    • #81148
      Bob,
      Yes, I see the sense of placing the hole near the rudder’s top, the trade-off being more drag against the hull en route to the winches. To be honest, I have not tried out what I have. When I haul out in the fall, I will.
      The only disadvantage of a hole instead of pad eyes is that you have to first reeve a 3′ line through it, preferably with stop knots both sides close to the hole. Then you can attach the steering lines with a sheet bend. So there’s an extra step compared to simply tying bowlines in the pad eyes. But considering the un-likelihood of its ever being used as opposed to the guaranteed permanency of the additional drag of pad eyes, I vote for the hole.
    • #81150
      Wow, nice setup, John. I put my emergency tiller on
      once when I first got the boat to be sure it fit, and I
      keep a homemade tool handy in the lazarette for opening
      that deck plate, but I have not set up any kind of
      tackle for actually using it. I believe I may have to
      copy your arrangement. (Hey, maybe I’ll write it up as
      a Cruising Tip for SAIL. Can I use your photo? (giving
      you the photo credit, of course, and a few cold beers
      someday by way of a royalty.)
    • #81149
      Good morning, Tor!
      Well, at least you’ll have a way to emergency steer if water gets in through the hole.
      Sort of like putting zippers in your bimini so you can remove it to replace the zippers.
      Like I should talk. I’m sitting here waiting for the tree guy instead of going sailing.
      Q
    • #81152
      Miss Kathleen
      Thanks all for your advice.
      My thoughts were to add a half-moon piece to the bottom, and was inspired by the pics in the link below where I saw a larger than normal rudder on the P424. Admittedly it is a sloop version.
      http://www.devalk.nl/en/yachtbrokerage/350137/PEARSON-424.html
      Looking at this it would be a project that definitely falls into the ‘hard basket’.
      At this point I have enough on my hands with the hard dodger and bimini rebuild.
      Other plans when she is on the hard is to replace some skin fittings and look at removing a few that are not needed.
      Another option is to install a PSS shaft seal.
      Cheers
      Dennis
    • #81154
      skipmac
      Hi Dennis,
      My last boat, a 34′ sloop, had a rudder like I think you are describing. It was a skeg hung rudder but the there was a section that protruded maybe 12″ below the bottom of the skeg and forward to the front edge of the skeg. So that lower section of rudder was balanced, ahead of the rudder post. The boat was very responsive and very light at the helm. The light touch I think was at least partly due to the balanced section. When you put the rudder over, the lower section had water pressure helping turn the rudder and made it much easier to steer.
      I have thought about doing the same thing with my Pearson. To avoid potential damage in a grounding I would make the lower section lighter in construction IE a breakaway section.
