Forums › General Discussion › Rudder shaft packing gland
Viewing 5 reply threads
    • #66958
      Hi All,
      I need to repack the rudder packing gland – have the packing but wondering if there are two nuts (one locking) and which direction they turn. I suspect right to tight, left to loose but would appreciate input. I'd hate to be whanging on them in the wrong direction…
      Pelican #8
    • #69659
      Robert, they were nomal threads on Sea Duty. They are both on the same set of threads.
      Turning them counter clockwise should remove them from the packing/bearing assembly.
      On Sat, Apr 26, 2008 at 12:55 PM, Robert Fine < ([email][/email])> wrote:
      Hi All,
      Pelican #8
    • #69661
      Thanks, Chuck!
      I wanted to be really sure as they probably haven't been moved since 1978 when they were put in. I've never seen a left hand threaded packing gland, but I've only seen maybe a dozen.
      Back in the hole I go with my can of PB Blaster…
      Hi All,
      Pelican #8
    • #69675
      Seawater
      I just did mine, it was righty-tighty.
    • #69703
      THanks Walter – I need a bigger wrench and hammer arrangement…
      Walter
      SV Madness
      P424 Hull #1
    • #69704
      Walter
      SV Madness
      P424 Hull #1
