Forums › General Discussion › Running without a thermostat
- This topic has 5 replies, 5 voices, and was last updated 13 years, 11 months ago by
quent.
January 5, 2012 at 12:12 am #68491
ParticipantMy W58 runs at around 190. The book says 180. Though I believe that 190 is acceptable, I was wondering about the effects of running without a thermostat. I’ve done this in my old “teenage” cars, but was curious about the necessity of a thermostat in a diesel engine. Any advice out there?
Ko Olina, O’ahu -
January 5, 2012 at 12:22 am #78066
ModeratorFirst, Dan, if you’re using the gauge as an indicator, get an IR
thermometer and check the temp around the thermostat. it could very well
be closer to 180. 190 is fine, though. However, diesels are not designed
to run cold – better to run at 190 than 160. Taking the thermostat out
isn’t a good idea.Bob
the necessity of a thermostat in a diesel engine. Any advice out there?Dan Kalinowski
January 5, 2012 at 2:13 am #78067
ParticipantMy 58 runs at 190, except when the alternator belt is slipping a little then it gets to around 200
Alan— On Wed, 1/4/12, kalinowski wrote:
January 5, 2012 at 3:30 am #78068
ParticipantYou’re right Bob. The IR says 180 at the thermostat housing, so the new T-gauge I installed is off by 10 degrees. Go figure!
Ko Olina, O’ahu -
January 5, 2012 at 2:43 pm #78069
RichCarterParticipantGood advice. Diesels don’t like to run cold. All kinds of problems can be caused by running them cold.
From http://soundmarinediesel.com/q_and_a.html#engineidling
# The engine is run at below operating temp, leading to carbon accumulation in the combustion chamber, injector tips, piston rings, piston crown, valves heads, seats, and stems, exhaust manifold, turbocharger, etc. Carbon on these parts will lead to accelerated wear, and possible piston ring sticking and low engine compression.
# Also, the injected fuel gets past the piston rings, because the engine is not at the correct temperature, and dilutes the lube oil. This compromised oil is sent to ALL the engine bearings, where it increases bearing wear.Regards
January 7, 2012 at 4:00 pm #78087
ParticipantW-58 thermostat also closes off a bypass that recirculates coolant back through the engine block. Running a W-58 without a thermostat will likely cause the engine to overheat.
