Forums › General Discussion › seal off/plug thru hull
- This topic has 15 replies, 6 voices, and was last updated 12 years, 9 months ago by
skipmac.
January 2, 2014 at 12:45 am #68836
cbboat
ParticipantWhat is the safest way to seal off a thru hull. I have one that I intend to remove next haul-out. Should the hole be plugged with something or filled with glass/epoxy?
January 2, 2014 at 1:21 am #80444
ParticipantA couple questions:
Is there a seacock on the through hull?
If so, what’s it’s condition?
Is the through hull plastic or bronze?
Is it above or below the waterline?
Location?
January 2, 2014 at 11:36 am #80445
ParticipantI removed 7 thru-hulls when I was upgrading my 424. It
was one of the few occasions when I elected to pay a
professional, to be sure it was done perfectly. Using
an angle grinder and plenty of experienced finesse, he
feathered the fiberglass out 3″ or 4″ radius from the
hole on the outside, feathered so that the ‘glass was
very thin at the edges of the original hole and
thickest at the feather’s perimeter of the feather.
Then he cut widening circles – from the hole size to
the extreme perimeter size – of mat & maybe some
roving, plus maybe the last 1 or 2 were cloth. Taping
some backed wax paper over the original hole on the
inside, the then wetted in each successively larger
cutout, building outward from the hole on the outside
of the hull, each patch overlapping a little move onto
the feathered ‘glass of the hull, until the last 6″-8″
circle of cloth was in place. He used polyester resin
for this. Once it set up, he sanded it smooth, then
coated with gel coat. It was a thoroughly professional,
very strong job that will last as long as the hull
does. To my knowledge this is the (only?) right way to
seal a big hole like a thru-hull.Have fun,
January 2, 2014 at 11:50 am #80446
Here’s some video explaining it similar to the way Tor had his done. There are a few video’s to get through and he can be a tad annoying but I feel he is doing a very adequate repair. it’s not rocket science. I plan to be doing up a few holes in the next few weeks. I’ll grind a small repair from the inside after I do a job more to the likes of Tor.
http://www.youtube.com/watch?v=gGr-OsUdf0A&list=PLV97GZkHhpHOKR_y03zg98Cxe6VLOq83B&index=2
January 2, 2014 at 12:03 pm #80447
ModeratorI do my own repairs, I use epoxy and biaxial cloth (two axis straight lines
with mat between and on one surface). I grind most out of the outside of
the hull, and some out (for two layers) on the inside. There is some
discussion about whether to start with the small circles first or the
larger ones. I see the point of them both, but I’ll do the larger ones
first from now on. I do the inside ones and let them start to set, then
start with the outside ones. If you have to wait, then a touch of sanding
on the outside before an acetone wipe will do the job.As Tor says, not rocket science.
doing up a few hols in the next few weeks. I’ll grind a small repair from
the inside after I do a job more to likes of Tor.http://www.youtube.com/watch?v=gGr-OsUdf0A&list=PLV97GZkHhpHOKR_y03zg98Cxe6VLOq83B&index=2
January 2, 2014 at 12:30 pm #80448
ParticipantYou know, my guy may have feathered back and built up a
little on the inside, as well. It was 7 years ago and I
may not be recalling it perfectly.Tor
January 2, 2014 at 12:37 pm #80449
ModeratorIt doesn’t matter that much, Tor, because the loading around those spots is
well below the capacity of the material that’s being put in there. To be
honest, you could put two thicknesses of mat there, well wet out, and it
would hold for the life of the hull. Where all the through hulls are, the
strength is far above the static or dynamic requirements, at least over the
area covered by the hole.Bob
January 2, 2014 at 1:54 pm #80450
Bob …What about redoing the gelcoat below the waterline, is it needed to be done if using epoxy? Tor, I’d bet your guy did. Of course I’ll be chatting up Dave, the fiberglass guy at Tiger Point Boat Yard too.
I’m getting ready to pull and rebuild as needed all my thru-hulls, along with removing and relocating a few. The new compost head is done and has really opened up the playing field below the sole. I haven’t got the whole plan layed out yet but am anxious to have her out of the water so I can get started. I wish I had more time but I really want to do some cruising this season.Ken
January 3, 2014 at 1:14 am #80451
ModeratorIf you use epoxy, you don’t need new gelcoat. If you use polyester, you
need to coat with epoxy or gelcoat.Best,
season.Ken
January 3, 2014 at 3:02 am #80452
cbboat
ParticipantThanks for the info, especially all ya’ll who have done this before. I figured tapering hole and patching was the way to go.
Quent:
Is there a seacock on the through hull? no, previous bozo put a ball valve directly on a mushroom thru hull.
If so, what’s it’s condition? seems ok, but hard to get to and not really needed.
Is the through hull plastic or bronze? bronze
Is it above or below the waterline? below
Location? waaayyyy down in port cockpit locker, real PITA to get to.I don’t want it anymore, too hard to get to, broken, bad installation, used for generator and I tee’d of engine seacock with ball valves, since i don’t run them simultaneously.
January 3, 2014 at 12:44 pm #80455
ParticipantLots of good advice here. Hole has got to go. I agree with Tor, find a good fiberglass guy, especially if the hull isn’t real thick at that location. Good advice above on woven fiberglass material. Don’t use mat.
Epoxy will stick to the hull better than polyester which forms a relatively weak secondary bond, hence the need for a long taper for contact area.
Clairebuoyant has 22 through hull openings, counting the transom. Gives me something think about on a long night off shore.
January 3, 2014 at 1:49 pm #80456
ParticipantPearson doesn’t sound like a Swiss name, but he sure
had a penchant for the cheese. 22 thru-hulls in a 42′
boat?! Crazy. I think Silverheels had nearly that many
when I bought her, but after my anti-hole rampage it’s
like this:Below-Waterline T-hull, Starboard Side #1
Intake to seawater intake manifold, which feeds the
following:
– galley sink
– watermaker
– toilet
– anchor/foredeck wash-down
– bilge hose-downBelow-Waterline T-hull, Starboard Side #2
– engine raw water intakeBelow-Waterline T-hull, Port Side #1
– galley sink drainBelow-Waterline T-hull, Port Side #2
– toilet dischargeThat’s 4 holes below the waterline, plus a
forward-scanning sonar thru-mounted.There are another 6 thru-hulls above the waterline,
plus a small hole high in the transom for the propane
locker drain.So, 10-12 total, depending how you count. Not ideal,
but an improvement.Tor
January 3, 2014 at 4:17 pm #80457
ParticipantSome t-hulls in Clairebuoyant are overcome by events. We no longer have water cooled refrigeration or a watermaker, so that’s four. If we pull out the dc kubota genset that’s two more. Hate to give up our massive investment in bronze seacocks, but all for the greater good.
Got my doubts about the sea chest concept. Seems like a lot of plumbing below the waterline. Recently saw a very pretty Tayana 48 with a custom fabricated stainless steel sea chest box that failed at a weld. Sort of an all the eggs in one basket problem maybe.
January 3, 2014 at 5:51 pm #80458
ParticipantI suppose a sea chest or seawater intake manifold is a
matter of preference and opinion. I see more potential
danger from 4 or 5 or 6 extraneous thru-hull fittings –
lots of unnecessary holes in the bottom – than from a
single, properly made and maintained distribution
chamber. Whatever floats your boat, I guess… and
keeps it floating.Tor
January 3, 2014 at 8:16 pm #80459
I really like the idea of getting rid of as many holes in the boat as possible and I’d like to do major improvements to a distribution chamber as Tor puts it but I also want to do some cruising. The salt water manifold (for lack of a better word) that I do have on board is in the aft lower compartment under the captains berth, just aft the hot water heater. I’d like to move it right out of there and leave space for a future battery relocation but that over-all project should wait till I get some use out this old girl, to make sure I fall head over heels in love with some cruise time gone by.
I’m planning on a month on the hard……we’ll see how the hustle goes week by week.
Happy New Year everybody!
Ken -
January 4, 2014 at 7:18 pm #80460
skipmac
ParticipantHi Tor,
I recall seeing a photo of your seachest on your website but last time I looked the photo eluded me.
Is it still there? Can you post a link or directions to find it. Want to do a similar setup and don’t see any point in reinventing that particular wheel.
Skip
