Forums › General Discussion › seeking replacement mast padeye
Viewing 9 reply threads
    • #68276
      Been stripping all the parts off the spars. I promise I have not been
      cursing. (watch words: Kroil, torch, cobalt bits, heavy duty Wera
      screwdrivers, patience)
      I did however break flange of one of the large padeyes. I wonder if
      you all could look at this part and tell me if this was standard Pearson
      or if the PO may have added them. These are on the main mast and I use
      to clip on my harness but they could also be used for whisker poles.
      There is one on each side of the mast. Loop hole ID is 1″.
      In any case, I would like to find a replacement. Anyone recognize the
      maker and know of a source?
      Here is the link to the picture:
      http://www.dublerfamily.com/Regina_oceani/padeye.jpg
    • #76853
      They weren’t standard – they are easily acquired from Forespar or Lewmar or
      someone like that. Easy peasy. Look at Defenders.com.
      I did however break flange of one of the large padeyes. I wonder if you
      all could look at this part and tell me if this was standard Pearson or if
      the PO may have added them. These are on the main mast and I use to clip on
      my harness but they could also be used for whisker poles. There is one on
    • #76854
      Nothing like this on my mast. Is it aluminum?
      Eric Lorentzon
      EFI Sales Development Manager
      412.352.1941
      On Mar 7, 2011, at 5:20 PM, Pete Dubler wrote:
      Been stripping all the parts off the spars. I promise I have not been cursing. (watch words: Kroil, torch, cobalt bits, heavy duty Wera screwdrivers, patience)
      I did however break flange of one of the large padeyes. I wonder if you all could look at this part and tell me if this was standard Pearson or if the PO may have added them. These are on the main mast and I use to clip on my harness but they could also be used for whisker poles. There is one on each side of the mast. Loop hole ID is 1″.
      In any case, I would like to find a replacement. Anyone recognize the maker and know of a source?
      Here is the link to the picture: http://www.dublerfamily.com/Regina_oceani/padeye.jpg
    • #76855
      Pete,
      This looks like a pad-eye for a whisker pole. Not one my mast, but I have
      been planning to add one. My guess Nicro-Fico.
    • #76856
      Wow, that was fast. I have not seen this particular design in any
      catalogs, but have not looked at defender yet. The PO spent a lot of
      time on the Med and got a lot of parts there.
    • #76857
      Pete,
      Bob is probably right – Forespar. I had these on my previous boat for the
      whisker pole. I crewed on a friends boat for races and these fittings were
      used for the reaching strut.
      catalogs, but have not looked at defender yet. The PO spent a lot of time
      or
      if
      on
      on
    • #76858
      Unless I’m mistaken, it’s an anodized aluminum pad eye. I prefer stainless
      ones, and they come with curved plates. I know I’ve seen yours at least
      within the last few years.
      or
      if
      on
      on
    • #76859
      Pete,
      I had two of these on my mast and removed them when I was re-doing
      things. The looked like original equipment to me. I use the ring on the
      pole track slide car for attaching the whisker pole. Pretty sure I’ve
      got both fittings in a locker somewhere. Let me know if you need them.
    • #76860
      Yes, cast.
      Eric Lorentzon
      412.352.1941
    • #76861
      I do not think Forespar makes a cast one these days. Only the welded
      one made of stainless.
      On 3/7/2011 5:29 PM, John Stevenson wrote:
      Pete,
      or
      if
      on
      on
