Forums › General Discussion › Shaft Lok
Viewing 12 reply threads
    • #69004
      My next project is a shaft lock to prevent the shaft and V-drive from spinning while sailing. It doesn’t bother me so much below 6 knots or so, but upwards of 8 knots it sounds like I have another motor running down there!
      Tor, I know you have experience with the Shaft-Lok, and I’m exchanging info with them at this time. Based on your previous comments that I read, sounds like you’ve had a learning curve with this equipment which I’d love to capitalize upon if you are willing to share. I don’t know the first thing about the subject, and do not have the remnants of the old shaft locking equipment aboard (apparently removed by the PO). I read that you installed the Shaft Lok on the ‘jack shaft’…I’m assuming this is the 1″ shaft from the transmission to the V-drive. And I’m not averse to cutting an access hole in the cabin sole to access the Shaft Lok.
      Any comments/suggestions are greatly appreciated!
      Blue Moon, #189
    • #81622
      Yes to all of that. I did install my Shaft Lok on the 1″ jack
      shaft – the only sensible place in our boats, I believe – and
      (better late than never) I did cut a small access hatch in the
      cabin sole above it. My second unit has performed so well so far
      that I suspect I got an off-day unit the first time. In any case,
      the owner, Ken Nigel, is extremely helpful and accommodating,
      ready and willing to guide you live by cell phone in the middle
      of an installation, advise by email anytime, and ship parts
      abroad quickly if needed.
      Since I don’t know of any viable shaft-locking alternative short
      of changing transmissions, I expect you’ll be happy with the
      Shaft Lok. As you get into the ordering and installation, feel
      free to pick my meagre brain for any info I might have to share,
      always remembering that the real authority on this is Ken Nigel.
    • #81623
      Thanks Tor. Your insight appreciated as always. I’ll let you know how things turn out (might be a while).
    • #81624
      I shall wait with bated breath.
    • #81625
      Hey Tor,
      You got my curiosity up. To put the Shaft-loc on the jack shaft, did you have to dissemble the jack shaft? I installed one on the prop shaft between the flange at the v-drive and the PSS shaft seal. Required the 1.5″ model versus the 1″ model you used. Difficult to reach but actually plenty of room once it’s on the shaft.
      Prop shaft turns at half the speed of jack shaft. Don’t really know if that’s an issue.
      Alternatively, a feathering or folding prop would work. Also, from what I’ve read, the Warner velvet drive transmission is okay with freewheeling. Maybe not the other transmissions.
    • #81626
      Not shaft-loc, Shaft-Lok.
      Q
    • #81627
      Quent,
      You have to disconnect any shaft to slide on the Shaft Lok
      mechanism. I chose the jackshaft in part because I could do the
      installation in the water. (I suppose you could back off and
      re-connect the prop shaft in the water, too, but I’m not sure of
      that and it didn’t seem like something I’d want to attempt.) I
      believe you’re correct regarding the faster-turning jackshaft. In
      truth I never thought of it before, but it certainly must require
      slowing down the boat more to engage the Shaft Lok than if the
      unit is mounted on the slower-moving prop shaft. Good point.
      Even if a transmission is OK freewheeling (because it
      self-lubricates without the engine running), I wouldn’t want the
      racket while I’m sailing, especially from the V-drive. My first
      preference would be one of the transmissions that locks in
      reverse once the engine is shut down. Frankly, if I had thought
      of it when I first bought my boat and repowered her, I’d have
      gone that route, obviating the need for an external shaft lock
      altogether. Of course, a feathering or folding prop will also
      solve the freewheeling problem without actually locking the
      shaft, except perhaps momentarily (which I can do if I shut off
      my engine in reverse). All of these alternatives make sense at
      the right time and/or the right budget. But since my tranny won’t
      stay locked in gear and is too new and healthy to replace, and
      since I haven’t bitten the bullet and bought a $3000-plus
      MaxProp, Silverheels gets along with the Shaft Lok. It’s not the
      ideal, but it works.
    • #81628
      For general information, below is the reply I most recently received from Ken Nigel, of Shaft-Loc:
      We received five beautiful photos and boat information…nice work! Yes, the information confirms the Mod II EL unit is the proper choice.
      The Mod II EL unit can be placed on either shaft.
      A. HOSE This has nothing to do with the Shaft Lok but in photo #1 (attached) the hose in lower right center of the picture looks crimped a bit. My take on that situation is that it will weaken further and close off completely. Think about replacing that hose sooner rather than later. Anne and I lived on Sea Ya II for 6 months a year for 8 years… http://www.shaftlok.com/MacGregor_65.htm
      B. The propeller shaft photo shows the packing nut. Having the Shaft Lok unit here would make servicing the packing gland difficult. Plus this area may produce some sea water fine spray at times.
      C. The V Drive shaft is higher out of the bilge area and it seems to have a full length keyway which could be used for one of the Shaft Lok stainless set screws…making the installation a bit easier. Also, the Mod II EL 1” bore is $621 and the 1 ½” is $819. Both unit components are in stock and will ship in 2 to 3 days after receipt of funds.
      D. A full scale drawing is also attached. Making a simple cardboard template may help you with the installation layout. The Mod II EL unit does not have to be in a vertical position. It can be mounted at 12 O’clock, 11 O’ clock or 9 O’clock or any angle, even upside down (but that would mean issues for routing the cable or locking the unit with the S.S.Locking System.) Keep in mind that the ATB (Anti-Torque Bracket) needs to be at 90 degrees to the force (parallel with the long axis of the name plate) generated by the locked propeller while sailing.
      E. Shipping via: United States Postal Service Two Day Priority Mail, insured with tracking number is $39.65. UPS is $37.58 insured and tracking with 3 to 4 days enroute. Both include $10 for Shaft Lok delivery to the carrier.
      Fair Winds,
      Ken Nigel
      Shaft Lok Inc.
      New Berlin, WI
      1 262 786 6800
    • #81629
      Price difference is certainly a factor. If I remember correctly, the jackshaft is not stainless steel, so a little anti-sieze might be a good idea.
      Q
    • #81630
      FWIW, I have a Martec Slipstream three-blade folding prop and I love it. Performance under sails is dramatically improved. There is absolutely nothing to snag a lobsta pot-line under sail. I suffer no performance penalty in forward and have no complaints with reverse. I still have my shaft brake rotor but I removed the calipers. I no longer need them. I think I paid about $2500 for the prop. A big prop like what the 424 needs is a custom order from Martec. I think you can buy them at a discount from Defender.
      http://www.martec-props.com/info_Slipstream.htm
      You should be able to remove the jack-shaft by unbolting it from the engine and sliding it forward, then sideways out of the way. I’m not sure that the jack shaft is the right place to put a brake however because any water that gets past the packing gland will splash on the brake. I suppose you might get away with this if you have a dripless box however.
    • #81631
      Hey Rich, I have the Martec Autostream S1 . Just curious, the PO spent a
      lot of time messing with his old fixed prop and working with Martec they
      came up with …19″ dia x 10 Pitch Left Hand. So far I can’t complain
      about the boats performance under power but I haven’t really had to put the
      pedal to the metal. What size and pitch is your prop???
      On Wed, Oct 15, 2014 at 9:48 AM, re.carter— via maillist <
      Defender.
    • #81632
      I have a 75HP engine and a 2.5:1 gear reduction in my V-drive so my experience might be different than yours. I have an 18.5x12LH.
      http://www.richardcarter.net/repower/Propeller.html
      You should put the pedal to the metal every once in a while. It blows out the carbon buildup in your engine. Your engine should push the prop all the way up to the redline. If it doesn’t, your prop is too big. Having an oversized prop is not good for your engine. I get near hull speed at about 80% of my redline (7.5kts @ 3000RPM). More throttle just pushes the stern wave up the transom for little speed gain. At most I get 7.8 kts at redline (3800RPM) but it sucks down the diesel and makes a racket. This prop seems to be a good match for me. You might not get full speed if your engine is smaller or if your prop is mismatched. Assuming that your engine redlines at about 2400 RPM, you don’t want to go to a longer prop blade because it will cavitate at high speed. 19″ sounds about right to me. Your pitch is less than what I have but your engine may be smaller. See if you can reach redline at full throttle on a calm day. If you have no problem but you’re only doing 7.0 KTS, your pitch may be too little. If however you’re struggling to get even near redline, your prop may have too much bite. Black smoke at full throttle and poor performance are a sure sign of a prop that is too big.
    • #82020
      Just a short report to let those that are interested that the Shaft-Lok is installed on Blue Moon and seems to do the trick. I sailed Sunday at speeds to 8 knots with no shaft rotation and no noise. Amazing how quiet it is without all that racket. I had to slow the shaft considerably for the lock to work, the major downside of a ‘lock’ vs a ‘brake’. I found the best technique to be to slow the boat till the shaft stopped, then fall off a bit to speed up, and as the shaft starts to turn, push in the knob.
      Installation was straightforward on the jack shaft. Access is pretty easy by pulling up the floor panel over the V-drive. I had to fiberglass in a small block to the hull to accept the anti-torque bracket, but nothing to that. I did not cut a hole in the cabin sole for access. Overall I’m happy with the product, though my experience is admittedly limited to one outing.
      David Tye
      Blue Moon, #189
