Forums › General Discussion › shower stall overhead
- This topic has 4 replies, 3 voices, and was last updated 17 years ago by
November 5, 2009 at 1:36 pm #67767
Has anyone taken down the shower stall overhead panel? I’ve removed most of the retaining trim pieces, but the
panel remains immobile. I now suspect Pearson bedded that piece to the inside of the coachhouse with silicone.
(I can see a little bit of the cursed stuff in one corner.) Anybody know?Tor
November 5, 2009 at 1:43 pm #74196
ModeratorI bet you're correct – silicone. That crap is all over. The good news is that it pulls right off. The bad news is that it adheres very strongly to the coach roof. You should be able to remove the panel without breaking it – but if you do break it, I think it's masonite or at the very best, laminate.
On Thu, Nov 5, 2009 at 8:36 AM, Silver Heels < ([email][/email])> wrote:
Has anyone taken down the shower stall overhead panel? I've removed most of the retaining trim pieces, but the
November 5, 2009 at 4:14 pm #74199
reluctant
Yes, mine was bedded with silicone. ‘All’ the trim had to be removed to get the panel out. I think I pulled down a corner and hacked at the silicone with a hand saw.
I reinstalled it using silicone but used much less of it. You only need a little support in the center, if the panel needs any additional, as the edges are well supported and the panel is pretty stiff. I didn’t use velco because I thought the adhesive might come unstuck with all the moisture.Have fun!
November 5, 2009 at 10:13 pm #74205
Nah, I decided I don’t really have to remove that panel for what I’m doing. I’ll just thru-bolt right through the sucker and dress the bolt ends with cap nuts.
November 6, 2009 at 5:43 am #74208
yes it was silicone. Mine panel came out in pieces    David Thompson
On Nov 5, 2009, Silver Heels <> wrote:Has anyone taken down the shower stall overhead panel? I’ve removed most of the retaining trim pieces, but thepanel remains immobile. I now suspect Pearson bedded that piece to the inside of the coachhouse with silicone.(I can see a little bit of the cursed stuff in one corner.) Anybody know?Tor~~~~~~~~~~~~~~~~~~~~~~~Silver Heels, P-424 #17maillist- ()For additional commands, e-mail: ()
To unsubscribe, e-mail: For additional commands, e-mail:Post generated from Pearson424 Forum using Mail2Forum
