Forums › General Discussion › small hatch over qtr berth
- This topic has 8 replies, 4 voices, and was last updated 15 years, 11 months ago by
allantereshko.
November 6, 2010 at 5:51 pm #68165
allantereshko
ParticipantHull #206 I need a riser arm for the small(approx 9″)hatch over the aft berth. The arm is 6.75 “. Is this the Bomar cast 100 series. and is Pompanette this right place to look. If so the parts for this small hatch is now showing.
November 6, 2010 at 6:21 pm #76208
john stevensonParticipantHatches over the aft berth were not standard from Pearson. This was likely
added by a previous owner and could be of any manufacturer. However, if it
has a riser arm it is likely from Bomar and Pompanette is the source.On Sat, Nov 6, 2010 at 1:51 PM, allantereshko <
> wrote:Hull #206 I need a riser arm for the small(approx 9″)hatch over the aft
is now showing._______________________________________________
November 6, 2010 at 7:05 pm #76209
allantereshko
ParticipantThanks John, by the way your Sarah site was a factor in buying my boat.
November 6, 2010 at 7:07 pm #76210
ParticipantDefender carries it at best price.
November 6, 2010 at 7:36 pm #76211
allantereshko
ParticipantI know it is a Bomar because of the knob. This riser body is 6.75″ and I can’t find anything that small online. Tha smallest is 15″. I really need the knob which turns without turning the stud but the knobs shown (male) have a 5/16th stud while mine is 7/16th. Any help much appreciated
November 6, 2010 at 8:58 pm #76212
ModeratorBelieve it or not, your local hardware store may have a selection of knobs
that will work. We have Karp’s True Value here and they have a big
selection of Bomar like knobs without the name on them.Also: Check out Grainger’s or McMaster-Carr. They also have a great
selection of knobs.Bob
On Sat, Nov 6, 2010 at 3:36 PM, allantereshko <
> wrote:I know it is a Bomar because of the knob. This riser body is 6.75″ and I
have a 5/16th stud while mine is 7/16th. Any help much appreciated_______________________________________________
November 7, 2010 at 1:42 pm #76217
allantereshko
ParticipantBob, thanks for the sites, I’m sure I’ll find what I need. The McMaster-Carr is incredible.
November 7, 2010 at 2:10 pm #76218
ModeratorGlad I could help – the knobs are used all over the industrial market and
you can even get helicoils if you want to renew the threads in the aluminum
fitting. Good luck!Bob
On Sun, Nov 7, 2010 at 8:42 AM, allantereshko <
> wrote:Bob, thanks for the sites, I’m sure I’ll find what I need. The
McMaster-Carr is incredible._______________________________________________
November 14, 2010 at 2:25 am #76238
allantereshko
ParticipantHow’s this for an example of Occam’s Razor, found the knob in question at the Ace Hardware in Rock Hall,Md. 5/16×18 three bucks.
