Forums › General Discussion › Spare original opening port for head
- This topic has 11 replies, 10 voices, and was last updated 17 years, 9 months ago by
unabated.
January 26, 2009 at 7:07 pm #67315
ParticipantDoes anyone have an original opening port for the head left over from a recent replacement? The wood butcher managed to torque down the dog so tight that he broke off the tang on the open glass part (a thin fellow, but his right arm looks like Popeye’s).
I would rather replace the port glass section rather than the whole unit for cosmetic purposes.
S/V Lady Leanne (#135)
Honolulu -
January 26, 2009 at 7:16 pm #71516
ParticipantA good welder can fix it for you, $50-100 (no need to ask me how I know). Advise said welder to make it muscular.
(212) 233 4995
(212) 385-4661 (fax)Confidentiality Notice: The information contained in this message and any attachments is privileged and confidential information, intended only for the use of the individual or company named above. If the reader of this message is not the intended recipient, you must not review, retransmit, convert to hard copy, use or disseminate this e-mail mesage or any attachments. If you have received this e-mail in error, please immediately notify the sender by return e-mail or telephone.
January 26, 2009 at 7:51 pm #71517
SpectatorYesterday at the Seattle Boat Show, I bought all new Stainless Steel ports from New Found Metals. I won’t start the project till Spring, but when I do I’ll be looking to sell the old ones at a reasonable price.
The six 5×12 plastic Beckson portholes (I don’t know if these are original or not) may not all survive the removal process. The four 4×17.5 cast aluminum (?) portholes will probably pop out just fine.I don’t plan on starting till at least April, so if your time-driven don’t rely on me. If you’re not, let me know what you need.
January 26, 2009 at 7:59 pm #71518
ParticipantWhat size NFM ports did you buy to replace the 4 x 17.5?
alan— On Mon, 1/26/09, Patrick Walters <> wrote:
January 26, 2009 at 8:49 pm #71519
RichCarterParticipantDan
Pearson used several different ports during the 424 production cycle. Mine came with aluminum framed ports with rounded ends. I may still have a pair of them somewhere if I didn’t toss them out. Is this the type you are looking for?Rich
BlackSheep #47
January 26, 2009 at 8:56 pm #71520
john stevensonParticipantDan,
What Rich posted is correct. Almost every 424 has a different port configuration. There are no opening ports in my head, but I do have a hatch over the shower stall.I don't have any spare portlights in my parts bin (how did that happen?), but it might help others if you posted a picture of the port you want to repair.
On Mon, Jan 26, 2009 at 3:49 PM, < ([email][/email])> wrote:
Quote:Dan
Pearson used several different ports during the 424 production cycle. Mine came with aluminum framed ports with rounded ends. I may still have a pair of them somewhere if I didn't toss them out. Is this the type you are looking for?Rich
BlackSheep #47
January 26, 2009 at 9:17 pm #71521
ParticipantJohn-
Are you talking about thesmall Bomar port? If so, I have someback in Maryland. Also, try Bacon’s. They usually have some opening Bomars both new and used.
January 26, 2009 at 9:48 pm #71522
SpectatorThe 3×17… I still need to double check some measurements (My order won’t be processed for 45 days) but I think they will fit just fine. The full size of the 3×17 is 20-1/2 x 6-3/4.
January 26, 2009 at 11:09 pm #71523
Along this line – I have been working on re-glazing and re-sealing mine the winter. Anyone know a good source for the gasketing?
January 26, 2009 at 11:16 pm #71524
ParticipantI just took a piece to the local chandlery and they matched it up with what I had. It was only a couple of bucks.
January 27, 2009 at 12:41 am #71525
ModeratorI went to Bomar, who originally made the portlights. “Oh”, they said, “we just stopped manufacturing that gasket! I may have a few inches around here…”
Then I looked for gaskets. No joy (I wish I had known your chandlery, Linus). I went to McMaster Carr and purchased a 30' piece of rubber, 3/8″ x 3/8″ and hey! Presto! It fits, it will never crush to leaking and it does the job.
Key is make the split at the top of the portlight (know how I know?) and re-adjust the screws on the hinges. Also, make sure the sealing blade is clean and smooth.
You should not need more than a few inch-pounds on the screws to seal the portlight properly.
January 27, 2009 at 3:14 am #71527
ParticipantI believe I have 5 or 6 of the gaskets – new…. in the box. I got the gaskets and found it too difficult to get them on…. so I purchased the new NFM ports instead…. I know…… I know but I wanted new ports anyhow and that just pushed me over the edge (GF actually bought them for me…….what can I say).
Lets me see if I can find them and go from there.
