Forums › General Discussion › SSB Grounding Article
Viewing 6 reply threads
    • #68040
      Tor and the group-
      Thought of you when I found this article by Gordon West re SSB capacitive ground. Check it out!
      http://www.kp44.org/ftp/SeawaterGroundingFor_HF_Radios_byGordonWest.pdf
      Rodd Leeds
    • #75547
      Thanks, Rodd. I’ve now downloaded that article and will read it ASAP. I’m
      about to set sail from Curacao for Cartagena, though, so maybe it’ll get
      read en route. I did ground my tuner as per Gordon West – 3″ copper foil
      strap to 3 bonded bronze thru-hulls plus an additional double-lag into the
      keel’s lead ballast – so I believe my counterpoise is right on. Still, my
      transmitting power is very weak. I need to get hold of an SWR meter to test
      things out and will soon, but I’m now suspecting the tuner simply may not be
      tuning. I’m not smart enough to know for sure, so I plan to have a pro check
      it all out in Cartagena.
    • #75548
      Rodd,
      Interesting. I know of several folks who regularly get good signal reports
      from HF rigs mounted in cars, even as low as 80m. There is clearly no
      contact with salt-water and have a meager ground plane. I think the 100sqft
      figure was left over from the days when everyone had LORAN receivers
      onboard. I still have mine in good working order. You need a big ground
      plane for a good LORAN receiver.
      I still suggest getting as much ground as practical. More can’t hurt, and
      you can never have too much. I have two bronze Dynaplates, one at the base
      of the mast and a second close to the antenna tuner with copper foil running
      between them. I’m spoiled though. I have good antennas at home and nothing
      I do on the boat compares.
      Lower frequencies require bigger antennas and bigger ground-planes. I’ve
      never been able to get my backstay to tune up on 80m and 160 is out of the
      question. I don’t think it’s a ground-plane issue though. Just a simple
      matter of the resonant length of the backstay. The SGC tuner doesn’t have
      enough adjustment. I’ll play with it next season and see if I can put
      something in there to help the SGC.
      If any of you hams out there want to play around with getting a Worked All
      States certificate, I recommend checking out OMISS. Download their software
      first and then log into one of their nets. They make it easy (almost).
      http://www.omiss.net/Facelift/
    • #75549
      I love a good side-by-side test! Thanks!
      On 6/7/2010 5:10 PM, Rodd Leeds wrote:
      Tor and the group-
      Rodd Leeds
    • #75580
      I just returned to Norfolk after a 6 day sail from Nassau. When I was in Nassau I added the KISS Ground Plane Antenna to my tuner. I am simply amazed at how much better my  rig worked on the way up. On the 5 and 8 mghz bands for SailMail, I can see at least a doubling of my power ou,t measured with an SWR. I was able to connected faster and at higher rates than I have been able to all winter.
      — On Mon, 6/7/10, Silver Heels wrote:
    • #75581
      Website link?
    • #75582
      http://www.kiss-ssb.com/
