Forums › General Discussion › Starting Battery
Viewing 14 reply threads
    • #66920
      I need to replace the starting battery for my W58. It
      was beginning to fail at the end of last season and
      during the winter it refused the take a charge.
      Question: What is everyone using for a start battery a
      27 or 29?
      When I removed the battery from the stock Pearson
      battery box yesterday I was surprised (not really)
      that the entire bottom of the box was rotted out. The
      battery was siting on only about 4″ of what remained
      of the fibreglass. Another freaking job, WOW, wouldn’t
      it be nice just to replace the battery without having
      to rebuild anything?
    • #69488
      Allan
      If it is only used for starting the engine, then all you need is a large
      automobile battery. I went down to my local discount outlet and bought the
      largest automobile starter battery they have. In truth, a lawn-mower
      battery would start my Yanmar, but there’s no need to get anything that
      small. My old W-60 would need to crank for as long as 30 seconds before
      starting, so it needed a larger battery. I assume your W-58 is similar. A
      deep cycle battery isn’t usually designed to function well as a starter
      battery, so they aren’t always the best choice in those applications.
    • #69489
      Hi Alan,
      I went to WalMart and got a group 29 or 31 (I forget which) which they call 'Marine Starting Battery'. It's only a year old, but it seems to be working – it's actually wired as bank 2, so it can perform house duties also for 10 or 15 minutes (that's a joke).
      The bank 1 is three 4D AGMs. I hope they last. They were expensive.
      On Mon, Apr 14, 2008 at 8:08 AM, Rich Carter < ([email][/email])> wrote:
      Allan
      battery would start my Yanmar, but there's no need to get anything that
      deep cycle battery isn't usually designed to function well as a starter
      battery, so they aren't always the best choice in those applications.
    • #69490
      Actually my W58 starts right up… after 2-3 seconds –
      maybe 10 if I havent run it in a few weeks. No more
      than that… which is why it’s still in the boat.
      Well, that and the fact I don’t have the money to swap
      it out.
      — Rich Carter <> wrote:
      Allan
      you need is a large
      truth, a lawn-mower
      those applications.
    • #69491
      If you are rebuilding the stock box (Mine was in the starboard locker, and
      took a LOT of room) you may want to consider re-locating. I put mine under
      the steering quadrant. This is space that is not very useable for anything
      that might shift, but ther is just barely enough room for a flat platform,
      T105, and a piece of plywood over the top to prevent interfering/shorting on
      the quadrant. I think I will be able to fit 6 T105s back there.
      I cut the Pearson box out two weekends ago with a sawzall, so I am committed
      now.
      There are some pics on the 424 website.
    • #69492
      Hi Walter,
      Do you not have an autopilot? That's where my actuator is.
      now.
    • #69493
      Walt, NICE JOB!
      What a great idea.
      Some of my space down there is taken up with an
      autopilot. But, I might have room for at least the
      starting battery. Since I am installing an automatic
      charge relay anyhow, the wiring will be a cinch.
      It will cleanup some of the stb locker.
      back there.
      now.
    • #69494
      Also, can you work on the rudder post packing? Or do you have to remove the batteries and box to work on it?
      On Mon, Apr 14, 2008 at 9:18 AM, Robert Fine < ([email][/email])> wrote:
      Hi Walter,
      now.
    • #69496
      Alan:
      Where was the stock starting battery box. The only stock boxes I have are
      for 2 x 4D’s. Was there a smaller box elsewhere in the starboard locker.
    • #69501
      I don’t have a real good picture but, Bank 1 is under
      the companionway boards in the picture
      Bank 2 is under what loks to be grey plywood.
      Starting battery is under the extension cord.
      Bank 1 and 2 are Trojan 125’s. They are end to end
      (for-aft)
      Starting battery is anthwartships.
      You can see the 1/2/ALL combining battery switch
      there.
    • #69504
      Alan:
      Thanks. I have the 2 original boxes that you have your Trojans in. Aft of
      them, I have shelves (not proper boxes as my surveyor made note of), with
      room for 2 more 4D’s, running for/aft. I hadn’t decided where I would put a
      separate starting battery, possibly where you have your water heater on the
      port side locker just beside the engine.
    • #69507
      Alan,
      I found the same totally rotten shelves when I first looked underneath the old batteries in my boat’s original starboard
      cockpit locker battery boxes. In addition, one of the boxes was partially saturated with battery acid, too. As I’ve
      described in the past, I relocated my batteries belowdecks (and switched to AGM’s). Then I tore out all the wood and
      remnant shelving in the old fiberglass boxes, washed the acid away with lots of baking soda solution, and now use the
      clean, empty twin boxes for general, compartmentalized storage. I may yet sawzall the whole thing out of there, but so
      far have not had a reason to do so.
    • #69508
      Re starting my W58. I have a “heavy duty” truck starting battery in my box–it was the smallest that would fit in what appears to be the original box. Starting motors should not be run for more than 15 seconds without a pause between starting efforts to allow it to cool. I always heat up the glow plugs before starting–I’ve been in Maine and the Martitme provinces for the last several years. Several seasons ago the glow plug circuit quit while we were in Georgian Bay. To assure a morning start, I would get up at 0100 or so to run the engine to keep it warm and covering it to keep it worm until moving time. Even at that it took an effort to start the vewry cold engine. When we finally gat back to port just north of Chicago, the starter was burned out from the extended running.
      Norris Larson on Easy Reach, 1983.
      alan P <> wrote:
      Walt, NICE JOB!
      What a great idea.
      back there.
      now.
    • #69524
      Thanks for the nice words, Alan.
      Yes, Robert, I have an autopilot, but it is mounted to the very top of the
      rudder post. The hydraulic ram is nestled between the fuel tank and the
      cockpit sole. The loads on the top of the rudder post are counterbalanced
      using a contraption of my own design that is …wait for it…patent
      pending.
      Access to rudder post stuffing will require moving batteries out of the way
      if you were to install 6 batteries. I think you could still service it
      without moving batteries if you only have 4 batteries back there. Mine does
      not need much attention, as it is normally above waterline.
      The other down side is access to check the water level in the batteries;
      everything has trade-offs.
    • #69529
      Hi Walter – you said the magic words – your packing gland is normally above the water line. Mine isn't (it's leaking which is a dead giveaway). I'm going to transfer all chain to forward of mast and move tools so that it comes up for repacking.
      The battery thing you did is beautiful, though, and obviously well thought out.
      pending.
