Forums › General Discussion › STEERING STUFFING BOX ACCESS
Viewing 2 reply threads
    • #69085
      Start of attached email. Subject: STEERING STUFFING BOX ACCESS
      JOE & JOHN – good morning:
      When you serviced your leaky rudder shafts, was it necessary to remove the
      cross beam thru which the shaft passes and/or the ply platform aft of the
      shaft in order to access the stuffing box…or did you hire a midget?
      End of attached email
    • #82267
      No, Bill, you should be able to get to the stuffing box under that beam. I
      found it easy if everything’s out of the aft lazerette and I sit on a
      cushion with my legs on one side or the other. It’s not fun, but it is
      doable.
      On Fri, Jun 19, 2015 at 7:51 AM, Boat1stlady— via maillist <
      Forwarded message
    • #82270
      Bill,
      The stuffing box can be serviced (re-packed) under the cross beam. I have
      a NL 4.5KVA genset in the lazarette so it is very difficult on Sarah. I
      have hire a boatyard muchkin to do the work. My wide body doesn’t fit.
      Sarah’s Blog
      On Fri, Jun 19, 2015 at 7:58 AM, Robert Fine via maillist <
      doable.
      Forwarded message
