Forums › General Discussion › Stem Eye for Anchor Rode Snubber
Viewing 3 reply threads
    • #68534
      Hey John,
      Your labels are correct, and you’re right; some of the stress from the
      anchor chain carries through the snubber line beyond the stem eye,
      towards end “A” – but not as much as you think. I don’t pretend to
      understand the physics of it, but there isn’t a lot of strain on the
      snubber between the stem eye and the shackle on the end of the anchor
      roller, and almost none beyond it to the cleat. Most of force is
      expended on the stem eye. (Note, too, that I don’t have an extended
      anchor roller platform, so a bit of strain on the anchor roller shackle
      is not a concern).
      As for chafe on the snubber line, I don’t care. You can see the old,
      thin line I’ve been using – just a scrap I had lying around when I
      decided to try out this approach. It has now held the boat for around 12
      months at anchor. It’s showing signs of chafe here and there, but so
      what. If it eventually breaks before I replace it and the windlass has
      to take hold of the anchor chain for a few minutes while I replace the
      snubber, it’s not a big deal. If it worried another skipper on his own
      boat, he could start out with a better piece of line and maybe even lay
      on some chafe protection. Then it’d probably last for years, if not
      longer.
      http://www.silverheels.us <http://www.silverheels.us/>
    • #78396
      Tor,
      Makes sense using expendable line for the snubber. It’s just that if the
      line is feed through either the stem padeye or bow shackle shown in your
      2nd pic, it seems to me that line could chafe through in a matter or hours
      not a season. I think I would at least run the line through a very large
      galvanized block on the stem padeye to ease a little of the chafe. But you
      say this is not necessary, at least in the short term.
      On Thu, Apr 5, 2012 at 6:43 PM, Silverheels wrote:
      Hey John,
      is not a concern).
      longer.
    • #78397
      John,
      You’re right, putting a block on the stem eye would certainly ease any
      tendency to chafe there. But as I said chafe hasn’t been a problem or a
      concern. On the other hand, a block on the stem eye would allow the
      strain to pass more easily through to the bow roller frame. It seems
      desirable to keep that strain focused on the stem eye, where you want
      it. In fact, double-wrapping the snubber line through the stem eye might
      be even better to keep the strain more fully centralized there. The
      skinny, 2nd-hand snubber line I’ve been using has withstood the little
      chafe that occurs for 2 winters of cruising now, and has held the boat
      through some serious blows.
      While the “end A” section of that snubber permits easy adjustment of the
      snubber length, it’s primary purpose is to enable me to cast it loose if
      I have to cut & run. Until then I want the anchor pulling on the stem
      eye.
    • #78398
      I can’t say for sure that lowering the snubber will effect sailing at
      anchor. If I were still out cruising, I’d compare a snubber at deck
      level with what I normally use (at the stem eye), but I’m on a mooring
      now in a harbor effected by currents, preparing to haul the boat for the
      summer.
      The ketch rig might indeed make some difference at anchor. Even with the
      mizzen sail furled, there is a certain amount of windage aft that a
      sloop doesn’t have. I suppose, too, that boat trim could make one 424
      behave differently from another. My boat is heavily loaded for long-term
      live-aboard cruising – I’ve raised the waterline twice! – and she’s
      slightly bow-heavy, to boot.
      Whether or not the stem eye eliminates sailing at anchor, it seems to me
      a better way to snub an anchor rode simply because it requires less
      scope for a given water depth, or else provides better holding for a
      given length of rode. Then again, that probably isn’t a big deal in most
      harbors. In the end it’s just a little perk I added because I could.
