Forums › General Discussion › Temp sender unit
- This topic has 6 replies, 6 voices, and was last updated 16 years, 7 months ago by
petedd.
March 10, 2010 at 5:37 pm #67936
ParticipantThe temp gage on our W 58 has given up the ghost (the gage pegs at 300 when the engine starts). Are these standard screw in units? Suggestions?
Lady leanne II (#135)
Honolulu -
March 10, 2010 at 7:01 pm #75048
RichCarterParticipantDan
I suggest checking with the instrument manufacturer to see which resistance sender you need. This can normally be done online using the instrument number. Then pull the sender and drive on over to the nearest auto-parts store. He can probably match the threads and resistance with a generic automotive sender. Chances are the threads are a standard 3/8 pipe-thread. I don’t have a W58, so I’m not sure.Regards
March 10, 2010 at 9:08 pm #75055
SpectatorLooking at the W58 Parts list:http://drop.io/DeepPlaya/asset/westerbeke58-partscatalog
I see that as PN 23571 Sender Water Temperature 1/8NPT
According to Torreson that PN is now 35109 which they sell for $76.56.
http://shop.torresen.com/marine_diesel_direct/Westerbeke/index.php?p=details&mfc=Westerbeke&sku=35109§ionid=5161I have no idea if that is a good price.
Honolulu_______________________________________________
https://pearson424.org/mailman/listinfo/maillist_pearson424.org—
March 10, 2010 at 9:46 pm #75057
RichCarterParticipantIts good for them but not so good for you. Their asking $76 for a $20 part. Check for a loose connection at the top of the sensor. That would cause the needle to peg if its open. A little PB-blaster on the connection might help.
March 10, 2010 at 10:20 pm #75059
ModeratorI've replaced both my oil low pressure switch and sender unit and gauge with standard units from Stewart Warner – go to an autoparts store and get a new unit for $20 or less. I think the original Westerbeke gauges are VDO. That means the senders are also. But they are so standard that you'll have no problem getting a replacement. Even if you have to replace the gauge, it's only another $30. So for all that, it's less than Torrensen.
March 11, 2010 at 5:34 am #75060
ParticipantThere were two temp “senders” on my W58. One is for the idiot horn and the other for the temperature gauge. I replaced my gauges with trusty and good looking VDO “cockpit series gauges” and made a new plastic panel. The whole panel with senders and the tach will go up for sale in a few weeks when my new panel comes with the new Beta Marine engine. ( I don’t want to leave a big hole in the boat in the meantime… I have a big enough hole in the sole where I am building the new fuel tank. I’ll take a picture of it this weekend.
https://pearson424.org/mailman/listinfo/maillist_pearson424.orgPost generated from Pearson424 Forum using Mail2Forum
March 12, 2010 at 10:02 pm #75015
ParticipantMost likely wiring. Check your connections, especially at the guage.
