Forums › General Discussion › Travel blocks removal
- This topic has 5 replies, 3 voices, and was last updated 18 years, 6 months ago by
madsailor.
April 14, 2008 at 7:50 pm #66923
The little white “pulleys” on my traveler are disintegrating. Yesterday I tried to unscrew them but had no luck – even with PB blaster and a good impact driver. The screws just turned.
Is my assumption correct that I have to remove the traveler from the deck to get at a nut on the backsides?Thanks – Eric
April 14, 2008 at 7:52 pm #69520
ModeratorHi Eric,
Many other owners have made a cut in the pylons that allow access to the inside. By cutting about 1″ from the edges on the outboard ends, you should be able to use a saber saw and then reach in. To finish the raw metal edges, you can purchase edging from an auto parts store or from Defenders.
April 14, 2008 at 7:59 pm #69521
RichCarterParticipantEric
You’re flogging a dead horse there. The original traveler that Pearson used was a piece of junk. If you can afford a boat unit, you might consider replacing it as long as you are planing to work on it.—
April 14, 2008 at 8:01 pm #69522
ModeratorI agree – check out Garhauer. They've made a number of travelers for the 424.
On Mon, Apr 14, 2008 at 3:59 PM, < ([email][/email])> wrote:
Quote:Eric
You're flogging a dead horse there. The original traveler that Pearson used was a piece of junk. If you can afford a boat unit, you might consider replacing it as long as you are planing to work on it.—
April 14, 2008 at 10:17 pm #69523
Running low on boat units….. Will try the cutout an add traveler to the want list (It was already there actually).
Robert Fine <> wrote:
Quote:I agree – check out Garhauer. They’ve made a number of travelers for the 424.Bob
April 15, 2008 at 1:58 pm #69528
ModeratorGood luck! Have fun. This will be one of the least expensive jobs you do.
On Mon, Apr 14, 2008 at 6:17 PM, Eric Lorentzon < ([email][/email])> wrote:
Quote:Running low on boat units….. Will try the cutout an add traveler to the want list (It was already there actually).Robert Fine < ([email][/email])> wrote:
Quote:I agree – check out Garhauer. They've made a number of travelers for the 424.Bob
