Forums › General Discussion › V-Drive
Viewing 17 reply threads
    • #67794
      I am poking around at my v-drive and thought some of you might like to see the pics where I opened it up a little bit.
      Input shaft http://www.flickr.com/photos/deepplaya/4115846727
      Cooling jacket http://www.flickr.com/photos/deepplaya/4115846789/
    • #74343
      Patrick, I found a similar mess in mine.  The offset vanes I was able to snap off with my thumb and forefinger.  I ended up with a new RV26.  Not a drop in replacement, some minor mods to the mount and engine output shaft.
    • #74344
      Pat
      You probably know that your cooling jacket is clogged with corrosion. Getting that stuff out is tedious. Good luck.
    • #74346
      Pat-
      The problem with cleaning out the cooling passage is that if you are too agressive,you will cause leaks between the cooling passage and the gear case. Water in there means the v-drive is toast. Walter suggets a thin layer of Marine-tex to seal the cooling passage after cleaning. There are several long discussions about alternative cooling schemes but the best solution is either a new v-drive, or a new gercase. RV-20 gear cases are out of production, and hard to find.
    • #74348
      I was thinking an epoxy coating.  That might work for a while…
      On Thu, Nov 19, 2009 at 9:15 AM, quent < ([email][/email])> wrote:
      Pat-
    • #74352
      The casing on our v-drive was almost completely blocked with corrosion/deposits with only a pencil thin passageway open. No wonder she ran very warm. Had it pulled and rebuilt for $450 (some new parts). She runs cool now with good flow through the exhaust.
      The mechanic baked the casing to remove all moisture before sealing the interior. He said this was the way to go as cast iron absorbs moisture because of faults in the casting process. Heating also supposedly reduces the brittle nature of the old casting. If you pull it out for rebuild, scratch mount positions so you don’t have to realign (assuming it is straight now)
      Hopefully we’ll get a few more years out of her. But I’m still chasing down the rumor of a new unit still in the box on Molokai’i.
      Lady Leanne II (#135)
      Honolulu
    • #74366
      I’m going to drain the water, pull the hoses, plug the dip stick hole and carefully (with light force) grind out that corrosion using a stainless steel brush. Then I can see what I have left. I think its not as bad as it looks, the pic I sent still had some of the paper gasket in the way and confusing what you were seeing, but we’ll see.
      Thanks!
      Sent: Thursday, November 19, 2009 3:48 AM
      To:
      Subject: Re: V-Drive
    • #74367
      The worst situation is seawater leaking into the gearcase. I never had any luck getting the paper gasket to seal. A bead of RTV allowed to set up before screwing down the cover instead of a gasket works OK for me.
    • #74368
      Be careful with removing the top of the casing. The metal on mine was so brittle that it easily broke in two when a light prying pressure was applied. We had to machine another using the original as a templet.
      Lady LeanneII (#135)
      Honlolulu
    • #74369
      Pat
      I tried everything, various cleaners, sandblast, wire-brush, dremmel tool, die-grinder and wheels. I finally used an old chissel and hammer. I carefully chipped away anything that could be removed. Then I went over it again with the die-grinder and various bits.
      I eventually replaced the damn thing. I think if you keep up with it every couple of years its not a bad job. Let it go and expect to have a mess.
      Good luck.
    • #74372
      Dan
      Did you contact Walter to see if they had a replacement or did you just figure it easier to make a new one?
    • #74373
      Rich: Our marina (Ke’ehi Marine Center) has a great machine shop,so I just had one made. It was a simple job and I thought it easier to make one. I never considered contacting Walter. However, I feel as though I’m living on borrowed time as the casing top broke so easily. When it broke, the metal flaked along the separation and I wonder how strong the rest of the casting is.
      Hopefully my repair will last for a few years and then (technology permitting) I can go electric.
    • #74374
      Dan
      You are correct. The case top corrodes just as the interior. When it gets thin it can break.
      My marine-tex repair held up quite well for several years. It still wasn’t leaking when I repowered and replaced the V-drive. I think these things could outlive us if we could just keep the water out of the cases.
    • #74378
      Dan-
      What material did the yard use to fabricate the replacement cover?
    • #74380
      I was told they used steel plate stock and cut it with a “chopper”. I have to admit I know next to nothing about metal fabrication. But they drilled the holes out and the cover fits fine. There was a small weep from one of the bolt holes in the casting. I was told that water fissures may permeate the casting and cause this. We dealt with this by putting permatex in the hole and installing a threaded stud. Sometimes I felt like the little Dutch boy trying to stop the leak.
      It all works fine now, but who knows for how long. I’m going to try to get in touch with the owner of “Mischief Maker”, the 424 that piled up on the beach in Lahaina (Oahu) to see if he wants to part with his v-drive if it’s the same unit.
      HOnolulu
    • #74381
      Do you know Mischief Maker’s hull number? If it is in the 130s or higher, she might have some W-58 parts worth salvaging.
    • #74384
      Quent: I’ll be back on O’ahu on the tenth and plan to contact the owner. I’ll report on the carcass then.
      Honolulu
    • #74389
      I did the same job two years ago. Most of the build-up came out without much effort. Cleaned inside, drain all the oil and flushed. We found very little wear after 3300 hours on the engine. After we put it all back together, I had the unit sand blasded (using baking soda), the yard then painted it with two part paint (end of a major spray job) – it looks and acts like new.
      Cada Grove
      Jubilee No. 100
      Thanks!
      To: ()
