Forums › General Discussion › v-drive
Viewing 6 reply threads
    • #68701
      Those of you who have replaced your V-drive, how did you know you needed to?
      What were the symptoms?
    • #79319
      Tor,
      My symptom was 30+ years old and some yacht delivery $$ burning a hole in
      my pocket. I had the RV20 rebuilt in the first year of my ownership and it
      never caused my any problems thereafter. I did have a lot of gear
      backlash noise at the time I replaced it, but it turns out that was the
      damper plate not the V-drive.
      So I guess my decision was based on an expectation it would fail in the
      near future and I could afford the replacement so it must be time to do it.
      I didn’t inspect the RV20 or have it analyzed after it was removed. It
      might have lasted another 30 years.
      to?
    • #79320
      Tor,
      From my experience Walters machining company is a great company to work with. I think if you talk to the owner he’ll tell you what to look for on whether to replace the RV 20 with the RV 26. in my experience I thought it was cheaper to have it rebuilt then to go through all of the hassles of putting the new RV 26 in. Plus the rv 26 is not cheap. if you get it rebuilt and you get another 10 years out of it. I think you did ok.
      In my case the seals were leaking and I had out of the boat anyhow, so I just had it rebuilt.
      On Apr 8, 2013, at 7:37 PM, John Stevenson wrote:
      Tor,
      to?
    • #79321
      Tor,
      The case cooling jacket will eventually leak into the gearbox. You can tell
      by pulling the dip-stick up to check the level. If you see that the oil is
      the color of chocolate milk, you have a leak. The bearings will fail from
      corrosion. It takes about 30 years for the jacket to rust through. You
      used to be able to replace the RV-20 cases but they are no longer available.
      The only real option is to replace with an RV-26.
      More info here.
      http://www.richardcarter.net/repower/Vdrive.html
    • #79322
      We were getting a lot of vibration and scheduled to have the v-drive
      mounts replaced (rusted). On the way to the yard it started throwing
      oil. The jack shaft was out of balance and the seals failed. We
      shipped it to the manufacturer for their appraisal and they reported
      they did not have the parts needed to repair it.
      No virus found in this message.
      Checked by AVG – http://www.avg.com
      Version: 2013.0.3272 / Virus Database: 3162/6232 – Release Date: 04/08/13
    • #79323
      Thanks to all of you – John, Alan, Rich, Dale – for your V-drive feedback. I
      think mine is OK.
    • #79324
      mark sherman
      We knew it was time to replace the v-drive when it froze up in the Bahamas. The good news was the sail back to Fl. M.J. Sherman on Nokomis (#183).
