Forums › General Discussion › V-Drive cooling
- This topic has 5 replies, 5 voices, and was last updated 10 years, 5 months ago by
theller85.
May 11, 2016 at 6:56 pm #220753
ParticipantSo it’s been a few years now since we talked about v-drive cooling.
I am ready to by-pass it, straight from strainer to pump.
I haven’t heard any negatives yet from the folks who have done it, so far. Is that pretty much the consensus.
Unabated -
May 11, 2016 at 7:25 pm #220754
skipmac
ParticipantI have bypassed my v-drive cooling but just splashed a couple of weeks ago and haven’t yet cranked the engine. I made the change based on reports from a couple of forum members that had done it some time ago and had no problems and one owner I’ve met a couple of times with the same experience. I don’t recall hearing anyone that had a problem after the change.
May 13, 2016 at 3:48 am #220867
I haven’t heard any negatives yet from the folks who have done it so far. Is that pretty much the consensus.
Unabated -
May 13, 2016 at 3:48 am #220868
JodyandStephen
ParticipantI spoke to a marine gearbox mechanic a few weeks ago, who said it probably wouldn’t be a problem, but that he would only be relaxed about it if the V-drive temperature was monitored. He suggested a temperature guage from the unit. He said whilst he did did not expect any issues running the unit without the water, they were designed to be water cooled for a reason. Are you considering measuring the temperature of the unit?RegardsStephen ParryS.V. Blue Pelican
May 13, 2016 at 12:50 pm #220916
Jack Clarke
ParticipantI bypassed mine a couple of months ago and just did a motoring passage from Norman's Cay to Lake Worth FL. 28 hours of the trip was in very light winds and the v drive temp was 140* and no problems.
Jack
Xanadu IV -
May 13, 2016 at 12:58 pm #220917
theller85
ModeratorBest thing to do would be to fill the case with oil. It will facilitate heat transfer out of the case into the environment and keep temps down.
