Forums › General Discussion › V-drive oil
- This topic has 16 replies, 5 voices, and was last updated 13 years, 7 months ago by
madsailor.
March 26, 2013 at 5:43 pm #68692
Several in this group have recommended using 90W oil in the V-drive,
claiming the heavier oil makes the drive much quieter. Is this any
particular kind of 90W oil, or just oil that says 90W on the label?Thanks,
March 26, 2013 at 5:47 pm #79269
ModeratorJust heavy duty 90 weight gear oil. That said, Walter does not recommend
heavy oil. I replaced mine with the 30 wt oil and noticed only a small
increase in noise level. But try it. It didn’t seem to hurt my drive.Bob
On Mar 26, 2013 1:43 PM, “Silverheels” wrote:Several in this group have recommended using 90W oil in the V-drive,
March 26, 2013 at 6:14 pm #79270
Bob,
Do you mean you tried 90W, and then changed to 30W and ” noticed only a
small increase in noise level?”Tor
March 26, 2013 at 6:25 pm #79271
I once had a slow leak around the seal where the shaft attaches to the drive, in Fronteras, Guatemala. Replacing the seal was not an option. A local mechanic said to relpace the 30w with 90w. The leak stopped and when I returned to our yard in Waukegan, Illinois, just north of Chicago, after a long slog through the Erie Canal under power and no leaks, I had them repair the drive. Some years later it was rebuilt at the factory in New Jersey with no apparent damage from the long use with 90w oil. After I reinstalled the drive I had the yard set the alignment, after a full day and night in the water. I suspect the seal leaks resulted from failure to properly align the drive. Because she was sold soon after that last repair, I dno’t know if any new leaks occured.
Norris LarsonPost generated from Pearson424 Forum using Mail2Forum
March 26, 2013 at 7:11 pm #79272
ModeratorWhen I got the boat it had 90 wt oil. To make my life easier and to only
have two types of oil aboard, I tried 30 wt which increased the high
frequency sound but not much. At least that was my experience. Also, my
prop freewheels so the noise is constant.Bob
On Mar 26, 2013 2:14 PM, “Silverheels” wrote:Quote:Bob,Do you mean you tried 90W, and then changed to 30W and ” noticed only a
March 27, 2013 at 1:34 pm #79277
I can only find reference to SAE 30 wt, non-detergent motor oil in any of Google searches.
Joe,
Half Moon________________________________
March 27, 2013 at 1:59 pm #79278
ModeratorRotella at Walmart and Advance Auto will work.
On Mar 27, 2013 9:35 AM, “Joseph Steiner” wrote:Quote:I can only find reference to SAE 30 wt, non-detergent motor oil in any of
Google searches.Joe,
March 27, 2013 at 3:21 pm #79279
ParticipantI have heard of folks using 30wt diesel engine oil for everything on the
boat: engine, v-drive, AND tranny. The trannys we use don’t “shift”
like the ones in our cars. They only do fwd, neutral, and rev. So, a
clean tranny (as in right after a rebuild) can use the 30wt engine oil
instead of transmission fluid. I wish I had done this when I rebuilt
my tranny (which by the way is a very easy job) (I do have gear oil in
my windlass though).Pete
On 3/27/2013 7:28 AM, Joseph Steiner wrote:
Quote:I can only find reference to SAE 30 wt, non-detergent motor oil in any of Google searches.Joe,
March 27, 2013 at 3:40 pm #79280
Man, I carry all kinds of oils:
Yanmar Engine
Rotella 15w-40 motor oil – 5.5 quarts / change
BioBor diesel fuel treatment/preservative
Paragon Transmission
Ford Type F automatic transmission fluid – 2-3 quarts / change
Walter V-Drive
SAE 30 heavy-duty motor oil like Exxon XD-3 – 1 quart / change
Honda Generator
10w-30 detergent oil for 4-stroke engines – .45 quart / change
Yamaha Outboard Motor
2-cycle engine oil – .25 quart (8 oz.) / 3 gallons gasoline
Sta-Bil gasoline treatment/preservative
Original MessageQuote:Post generated from Pearson424 Forum using Mail2Forum
March 27, 2013 at 3:45 pm #79281
ParticipantAnd don’t forget the old oil from the last oil change at sea…
and WD-40, liquid wrench, spray silicon, drislide, mclube,…On 3/27/2013 9:39 AM, Silverheels wrote:
Walter V-Drive
Honda Generator
March 27, 2013 at 4:10 pm #79282
I actually included a “Chemicals to Carry” section in my “Ready for Sea!”
book. It lists about 4-dozen “must have” items. That was in 2002. I’ll bet I
could add another 1 or 2 dozen products now.Tor
March 27, 2013 at 4:35 pm #79283
ModeratorIt depends on your transmission. Only the Paragon will use 30 wt oil, I
believe.I’m not being terse. This is from my mobile.
On Mar 27, 2013 11:21 AM, “Pete Dubler” wrote:Quote:I have heard of folks using 30wt diesel engine oil for everything on the
boat: engine, v-drive, AND tranny. The trannys we use don’t “shift” like
the ones in our cars. They only do fwd, neutral, and rev. So, a clean
tranny (as in right after a rebuild) can use the 30wt engine oil instead of
transmission fluid. I wish I had done this when I rebuilt my tranny
(which by the way is a very easy job) (I do have gear oil in my windlass
though).Pete
Google searches.
Joe,
Half Moon______________________________**__
March 28, 2013 at 3:36 am #79284
ParticipantRotella 30 weight. I put that s**t in everything.
March 28, 2013 at 6:16 am #79285
SpectatorThat’s what they recommended for my high-mileage RV this summer. Funny
thing, it was not with the other oil at the auto store. It was in a special
“more expensive” section. The sales dude said all the truckers used it.-p
http://www.DeepPlaya.com | @DeepPlaya | W7PEAOn Wed, Mar 27, 2013 at 9:36 PM, Adam Silverstein wrote:
s/v Phantom Corsair_______________________________________________
March 28, 2013 at 11:53 am #79286
ModeratorThat’s it! Three Transmissions:
– Hurth – ribbed and squarish. Can freewheel, locks in reverse – uses
ATF
– Paragon – hydraulic – cannot freewheel because of insufficient
lubrication – uses ATF, don’t know about oil.
– Velvet Drive – hydraulic – happily freewheels, should not be left in
gear – uses ATF or 30 wt. oilBob
http://www.DeepPlaya.com | @DeepPlaya | W7PEAOn Wed, Mar 27, 2013 at 9:36 PM, Adam Silverstein <
March 28, 2013 at 12:23 pm #79287
That’s great info, Bob. Thanks. I hope I never have to change trannies, but
if I do I’ll get a Hurth for the lock-in-reverse feature, plus the option of
freewheeling to generate electrical power.Tor
March 28, 2013 at 12:32 pm #79288
ModeratorYou’re welcome. There was a huge, long discussion a few years ago on the
mailing list about this and this was the takeaway. Glad I could help.Bob
On Thu, Mar 28, 2013 at 8:23 AM, Silverheels wrote:
Quote:That’s great info, Bob. Thanks. I hope I never have to change trannies, but
of
