Forums › General Discussion › Valve job, w-60
Viewing 4 reply threads
    • #68311
      Adjusting valve clearance, is cylinder 1 nearest the flywheel? Also, and perhaps more importantly, which is the intake and which is the exhaust for each, if you are facing the flywheel? The tolerances are slightly different (.012 in, .015 ex).
    • #77035
      Hi Adam-
      W-60 manuals here:
      http://www.carpcoastalmarine.com/index.php/west_cat
      Should answer your questions.
      Best regards,
      Clairebuoyant #132
    • #77042
      (212) 233 4995
      (212) 385-4661 (fax)
      Confidentiality Notice: The information contained in this message and any attachments is privileged and confidential information, intended only for
      the use of the individual or company named above. If the reader of this message is not the intended recipient, you must not review, retransmit, convert to hard copy, use or disseminate this e-mail mesage or any
      attachments. If you have received this e-mail in error, please immediately notify the sender by return e-mail or telephone.
      On Apr 17, 2011, at 6:57 PM, “quent” wrote:
      Hi Adam-
      W-60 manuals here:
      Best regards,
      Clairebuoyant #132
    • #77043
      Thank you, but I have a manual (two actually-I made a nice bedside edition and a working edition). For whatever reason, I cannot find this information in the technical manual or the service bulletins.
      Adam
    • #77044
      Hi Adam,
      Usually, number one cylinder on an in line engine is the first one at the
      front where the harmonic balancer is (or the pulleys that drive your
      accessories) – realizing that your engine is backwards, number 1 is facing
      the fuel tank.
      Intake and exhaust valves are a little more difficult to grok. If your
      engine is cross head, meaning the intake is on one side and the exhaust is
      on the other, the valves are arranged side to side and they are on the same
      side as their manifold. If they are fore and aft, it’s a little harder.
      I’m looking at the manual and they’re fore and aft. It looks like the
      valves aren’t the same for each cylinder – it looks like the valves go from
      #1 cylinder, intake, exhaust, exhaust, intake, intake, exhaust, exhaust,
      intake.
      You can do the procedure to align #1 on top dead center (I didn’t look that
      up, but I’m sure it involves a mark on the flywheel or the harmonic damper),
      and adjust the valves in order. Even if you’re 1/2 cycle off, the valves
      will be closed and you can check their clearance.
      service bulletins.
      Adam
