Hi James,
By eyeball is perfectly ok. It just has to be pretty close – you'll know if it's wrong because the belt will look twisted and there will be a great deal of wear dust from it.
On Thu, May 7, 2009 at 12:30 PM, james bartch < ([email][/email])> wrote:
Aloha to All
I recently had to replaced the Sherwood water pump on my w 58 and was told that i should double check the aignmnet (because the way it bolts on allows, for some movement). When i installeld it i just made sure that the pully was located in the same position that it was taken from and bolted it back up. Do i need a special tool for aligning it or can i align it my self by site or??? please reply.
James
Hull #8
