Forums › General Discussion › W-58 starter
Viewing 5 reply threads
    • #68730
      If I’m reading this correctly:
      http://www.spidermarine.com/ShowItem/111095%20Delco%2012%20Volt%2010%20Tooth%20Westerbeke%20Starter.aspx#xRef
      Then there are a whole bunch of relatively common westerbeke engines that use the same starter as the W-58!
      That might be good to know in a pinch.
    • #79517
      Probably true. My old W60 starter was a common starter used in industrial engines such as fork-lifts. Hansen, the local Westerbeke dealer, offered to rebuild mine for over $600 many years ago. I got a brand new one from a local starter repair shop for about $150 instead. That’s why I now own a Yanmar.
    • #79518
      That should mean that the W58 and the W60 should be identifiable industrial
      engines. The only thing you’d ever need would be the exhaust manifold and
      I’ll bet there’s a way to jerry rig that.
      Yanmar.
    • #79519
      Bob,
      I’m not sure about the entire engines. I heard that the W60 block was from Leyland off a British taxi. Westerbeke wisely chose not to use a Lucas starter. The electrical system in my old MG was Lucas and notoriously unreliable. I have no idea where the W58 originated. The optional high-capacity alternator that came with my W60 came from a deuce-and-a-half truck.
      The nomenclature used by Westerbeke is deceiving. The W60 wasn’t 60hp, more like maybe 50 on a good day going down-hill.
    • #79520
      I’ve heard that the W58 is a Mazda B2000 diesel engine. But that engine
      was never imported here in the B2000, but probably as forklift or other
      industrial engine. I wish there was a law that allowed people to know what
      engine is the basis of the marine engine they have. But I seriously doubt
      that would happen.
      On Wed, May 29, 2013 at 4:46 PM, wrote:
      Bob,
    • #79521
      You might also check, I think this engine might also have been used in a 1985 Ford Ranger Diesel. I know that the W63C uses this Ford Diesel engine made by Mazda. RockAuto.com has parts for older diesel engines.
      S
      ________________________________________
