Forums › General Discussion › W58 Water Temp Switch – not sender
- This topic has 6 replies, 4 voices, and was last updated 15 years, 6 months ago by
unabated.
April 27, 2011 at 12:49 pm #68323
ParticipantI need to replace the Water Temp Switch ( not the temp sender). It is part of that AquaAlarm system with the Oil Pressure and Water alarm.
It’s the one with the 2 contacts. Any one have an actual part number?
April 27, 2011 at 12:57 pm #77158
Go to auto parts store. They ain’t no thing. Just ask for sender w pos and neg with your temp range.
(212) 233 4995
(212) 385-4661 (fax)Confidentiality Notice: The information contained in this message and any attachments is privileged and confidential information, intended only for
the use of the individual or company named above. If the reader of this message is not the intended recipient, you must not review, retransmit, convert to hard copy, use or disseminate this e-mail mesage or any
attachments. If you have received this e-mail in error, please immediately notify the sender by return e-mail or telephone.On Apr 27, 2011, at 8:48 AM, Alan wrote:
April 27, 2011 at 1:00 pm #77160
Oh. Sorry (Not sender).
(212) 233 4995
attachments. If you have received this e-mail in error, please immediately notify the sender by return e-mail or telephone.On Apr 27, 2011, at 8:57 AM, Adamlaw wrote:
(212) 233 4995
April 27, 2011 at 1:01 pm #77161
RichCarterParticipantits just an automotive temperature switch. You can bring it to any auto-parts store and get a match.
April 27, 2011 at 7:36 pm #77162
ParticipantThat might be Westerbeke 30125
http://shop.torresen.com/ships_store/index.php?p=details&mfc=Westerbeke&sku=30125
I said “might” because this one appears to mount in upper t-stat housing. Other switches mount in lower housing including our engine. Apparently Westerbeke made some cooling system changes in 1981.
Suggest that you download Westerbeke manual and parts list for W-58 which are available for free as PDF docs on internet.
You might also try Ebay.
April 27, 2011 at 7:37 pm #77163
April 27, 2011 at 8:21 pm #77164
ParticipantQuent,
Thanks, took a bit of digging but I found it – 30125 is a single contact sender – yes in the upper housing.
39550 is the W.T. switch in the lower housing. They have changed the number a few times.
BTW the O.P switch is 37323
Alan— On Wed, 4/27/11, quent wrote:
