Forums › General Discussion › Was: Water pump to trade…Now Kubota Generator Parts
Viewing 8 reply threads
    • #67367
      Pete,
      I have that same 6 hp Kubota engine. I picked it up from a smashed Highway signboard.
      This one has a fan cooled radiator. I would like to marinize mine. Specifically I am looking for a heat exchanger and setup for a water muffler. Where did you find your parts? Did you have them made or did you purchased them?
      Also, where are you planning on mounting this beast? I am thinking the lazerette.
      Any plans, drawings or pictures would be greatly appreciated.
    • #72063
      Alan,
      I did get the pump exchanged so I am set on that.
      Plan to put it in the port lazarette.
      I cut the exhaust myself and had a friend TIG it up.
      For the heat exchanger, I got a Phasor heat exchanger. I have seen a few on ebay once in a long while but I bought it from the guys in Florida that make the Phasor generators. I turned the hub adapter on the lathe out of steel (6″ diameter rod stock) and the custom pulley out of aluminum. I replaced the “oil pan” with a sheet of 3/8″ aluminum plate and, after making this three times, finally got everything the way I want it. The R30G pump fits into a groove in the plate and runs on a timing belt off of what used to be the shaft one could connect a hand crack starter. I’ll take some more pictures so you can see the other side soon and will post them to the website by and by.
      Alan P wrote:
      Pete,
    • #71796
      Pete,
      Thanks for the info.
      So you using the RG30 for the Freshwater pump, belted to the engine and an electric pump for seawater?
      How much $$ was the Phasor Heat exchanger? Do you have a URL for them?
      In my afr lazerette, they were some floor boards with some flimsy stringers to attach them to. I was planning on beefing up the stringers and mounting the Kubota acoss them. I figured 150 lbs would not matter too much back there. Although in the port sail locker (lazerette) would offset the weight of the batteries in the starboard side…..but I have a nice shelf in there. Maybe under it?
      — On Wed, 2/18/09, Pete Dubler <> wrote:
    • #71805
      R30G for seawater. The engine coolant moves by convection. There is no
      pump for that. Don’t recall and can’t find what I paid for the
      exchanger. Just search on Phasor generators and give them a call.
      Alan P wrote:
      Pete,
      — On *Wed, 2/18/09, Pete Dubler /<>/* wrote:
    • #71809
      Our similar, temporarily defunct DC genset uses same Kubota EA 300. Phasor in FL is also Kubota distributor and a good source for Kubota engine parts which incidently are much cheaper than Westerbeke parts.
    • #71810
      I am trying to contact the Phasor dealer that shows up when I GOOGLE them but the contact address is NG. Have you a name that I can contact or an E-Mail address?
      — On Thu, 2/19/09, quent <> wrote:
    • #71811
      The reason I asked about the pump was because on your electrical (generator.bmp) it shows a water pump tied to your fuel pump.
      — On Thu, 2/19/09, Pete Dubler <> wrote:
    • #71813
      Try Southeastern power.com both Phasor and Kubota. 954-979-4349.
      However they don’t take credit cards, so they hooked me up with Carlos at powerresolutions.com their retail dealer. Same prices and prob. drop shipped. 305-512-1018 http://www.powerresolutions.com.
      Google kubota engines and look at their distributer list
    • #71815
      Yup,
      My mistake. On my first generation version, I was using an electric
      pump, but I replaced that with the mechanical pump.
      — On *Thu, 2/19/09, Pete Dubler /<>/* wrote:
