Forums › General Discussion › water heaters
Viewing 7 reply threads
    • #68279
      Has anyone installed a tankless water heater? We are spending more and more
      time away from the dock and the admiral misses her showers and hot water to wash
      the dishes.
      lee
    • #76870
      I have note, but I love a good research project. You thinking of a propane
      model or an AC model for use at the dock?
      more
      wash
      the dishes.
      lee
    • #76871
      I suggest the propane model so you can use it without the generator or
      dockside electric. But Lee, you have a generator – why not use it to heat
      the water and charge the batteries?
      On Sat, Mar 12, 2011 at 12:37 PM, Patrick “Peaboy” Walters <
      more
      to
      wash
      the dishes.
      lee
    • #76872
      Bob,
      My generator is a 120 AMP DC unit. I doubt I can find a 12 volt DC water heater.
      The Kubota generator does not produce much hot water. I have never seen water
      temps above 110 degrees.
      lee
      Original Message —-
    • #76873
      The 120 amp DC will run the inverter which heats the water. My 2000 watt
      Honda will heat the water. 120 amp @ 12V is 12 amp at 120V (approx 1440
      watts). Your heater may be rated at 1500 watts, but doesn’t really draw
      that. You could try it – the worst that would happen is you’d pop a
      breaker, if there’s one on the generator.
      On Sat, Mar 12, 2011 at 1:22 PM, Lee Yonkers wrote:
      Bob,
      heater.
      water
      lee
      Original Message —-
    • #76874
      Lee,
      A few years ago I looked in to propane hot-water-on-demand for my boat.
      Turned out I don’t need heated water very often in the tropics, but I
      recall discovering that some of the guys who made or were connected with
      the old Wolter HWOD units (which had problems and were eventually
      discontinued) began manufacturing a better quality unit under a
      different name. I shared that info with this group back then, but can’t
      find it now. If you do some keyword Googling you should be able to find
      their web site.
      I used a Wolter for 6 years of full-time liveaboard cruising aboard my
      last boat. That unit had some issues, but in principle I believe it’s
      the smartest way to heat water on a sailboat. The new generation of
      those seemed to be very good, if a bit pricey.
      Please let us know what you find out.
    • #76875
      You can also get 12V coils for a HWH. These are often used as a sink
      for excess wind or solar power. Some HWHs allow for multiple sets of
      heating coils.
      Bob,
      heater.
      water
      lee
      Original Message —-
    • #76876
      Interesting threads:
      http://www.sailnet.com/forums/gear-maintenance/58724-propane-demand-water-heater.html
      http://forums.sbo.sailboatowners.com/printthread.php?t=47273 (Our very own
      Jack chimes in on this one)
      Without thinking about this too deeply if it has no pilot (the only thing
      I’d consider) then it’s going to need some power to light. Venting will be a
      concern of course. Maybe build another “propane” locker in the aft starboard
      cockpit (my propane is aft to port) and enclose it there to both vent it and
      handle leaks…
      On Sat, Mar 12, 2011 at 3:41 PM, Pete Dubler wrote:
      You can also get 12V coils for a HWH. These are often used as a sink for
      excess wind or solar power. Some HWHs allow for multiple sets of heating
      coils.
      Bob,
      heater.
      water
      lee
      Original Message —-
