Forums › General Discussion › water makers
- This topic has 4 replies, 4 voices, and was last updated 16 years, 10 months ago by
john stevenson.
December 19, 2009 at 2:49 am #67846
Does anyone have a water maker? If so: what kind, what size, where did you put it, are you happy, etc.
Lee
December 19, 2009 at 11:10 am #74575
ModeratorHi Lee,
Yes, I was given a Powersurvivor 35 and I had it refurbished at Katadyn. It's installed under the floorboards inboard of the stove. I'll show you when I get there.
December 19, 2009 at 11:37 am #74576
ParticipantI installed a Kubota e300 in the aft lazerette I put a CAT HP pump on there that will do about 4.5 gpm. It goes thru a SW2540 membrane. I get 32gph of good water out at 120ppm.
Home brewed of course. it’s not rocket science. Cost so far about 2500.
UNABABTED— On Sat, 12/19/09, Robert Fine <> wrote:
December 19, 2009 at 11:47 am #74577
ModeratorThe Powersurvivor 35 does 3+ gallons an hour at 6 amp/hours. With the shaft generator running under sail, it powers it at 5.5 knots. Otherwise, need the engine or generator…
December 19, 2009 at 12:56 pm #74578
john stevensonParticipantJack & Particia Tyler went through the multi-step process of deciding to add a watermaker, picking one that met their needs and then installing it. They only considered the commercial products in their process.
http://www.svsarah.com/Whoosh/WhooshPacificPrepWaterMaker.htmlOn Sat, Dec 19, 2009 at 6:47 AM, Robert Fine < ([email][/email])> wrote:
Follow me at: http://www.tinyurl.com/WhereIsBobFine—
