Forums › General Discussion › water tank capacities
- This topic has 8 replies, 7 voices, and was last updated 17 years, 3 months ago by
john stevenson.
July 28, 2009 at 8:11 pm #67617
ParticipantDoes anyone know the separate water tank capacities of the side and bow tanks? All I can seem to find is the total of all tanks together. I’m doing some serious tank cleaning and need to know volumes for the proper cleaner mix.
Lady Leanne (#135)
Honolulu -
July 28, 2009 at 8:36 pm #73327
SpectatorI am 99% sure its 60+60+20
July 28, 2009 at 8:36 pm #73328
patn
ModeratorOurs is 70 gallons in the bow, 50 each port and stbd.
– pat
proper cleaner mix.Dan Kalinowski
Lady Leanne (#135)
Honolulu
July 28, 2009 at 9:13 pm #73329
ModeratorMy catalog for the boat says 50, 50, and 60. I think it's correct. But it's an early model.
– pat
Does anyone know the separate water tank capacities of the side and bow tanks? All I can seem to find is the total of all tanks together. I'm doing some serious tank cleaning and need to know volumes for the proper cleaner mix.
Lady Leanne (#135)
Honolulu
July 28, 2009 at 9:52 pm #73330
Spectatorall different answers…. now I have to fill my tanks with a teaspoon so I can precisely measure them… the projects never end. 😉
July 29, 2009 at 12:19 am #73331
WOW! Mine is 60 – 60 and 50 in the bow, hull #71.. I’m sure that’s correct.
Joe,
Half Moon— On Tue, 7/28/09, Robert Fine <> wrote:
July 29, 2009 at 1:16 am #73332
60 /60, & 50, roger that
Capt Bill Tice, aboard s/v CHARISMA, hull# 118Post generated from Pearson424 Forum using Mail2Forum
July 29, 2009 at 2:43 pm #73334
Syringa
ParticipantTo find out the capacity of a water tank: 1. Start with a empty tank. 2. turn your dock water hose to a medium flow. 3. time how long it takes that flow to fill a one gallon jug. 4. Move hose to tank you want without changing flow and start timing . 5. Divide the fill time by jug time = gallons.
July 29, 2009 at 9:47 pm #73336
john stevensonParticipantThe owner's guide I inherited from the PO says the 3 tanks have, ” a total capacity of approximately 150 gallons”. The spec sheet in the same guide says a total of 170 gallons. I suspect we will find that few of our boats have the same capacity. If we want to know the true capacity we'll have to measure the tanks on our boats and not use a spec sheet or the measured results on any of the other boats.
Don's method will work if you are the only boat on the dock using the water. On many of the docks on which I've kept my boats if two other boats on the same dock are using their hoses your water pressure will drop significantly. My specific experience when I had both cabin tanks empty I timed filling the port tank at (if I remember correctly) a little over 18 minutes. So for the starboard tank I didn't bother removing removing the settee cushion, but just started timing it. Apparently someone on the dock turned off their hose about that time and the tank overflowed in less than 12 minutes. My water outlet was the furthest one out the dock.
So you have to be sure the water flow doesn't change.On Wed, Jul 29, 2009 at 10:43 AM, Syringa < ([email][/email])> wrote:
Don Gardner
S/V Syringa #124/)+/)+~=:)
