Forums › General Discussion › water tank leaking
Viewing 10 reply threads
    • #67056
      svtopaz
      I have a leak coming from the portside water tank, I believe. It is dripping on the portside under the floor boards near the mast. I am trying to get to the tank on that side but it looks like I might not be able to get to easily. Anyone have problems with thier tanks leaking? or hoses ? I just filled the tanks from the bow and overfilled of course. When I have done that in the past the water just runs into the bilge and runs into sink. But never a leak afterwards. I have looked at the inspection hole and no leak there and have a cut out forward to look at hose going into the tank itself and another smaller hose(clear) going somewhere forward, but I see no leaks. Under the floor there is a clear hose going forward, I am assuming to the bow tank. I can only see so far on that one. I am clueless on system of course hoping some one could give me more info on this list.
      Barbara
    • #70156
      Barbara,
      I just ordered and installed a new set of O-rings for the inspection ports on my water tanks, since most
      of them leaked when the tanks were filled to the top. My salon tanks have three inspection ports each,
      but only one per tank is accessible through the slide-out plywood bunk extension piece. In other words,
      when you lift the settee cushion you only see one access port, reached through holes cut in the plywood
      covers. However, removing the slide-out plywood pieces covering the salon tanks (underneath the settee
      cushions) reveals two more inspection ports per tank, one for each baffled compartment of the tank. If
      your boat also has these check them for leaks around the screw-out center piece. If they’re leaking,
      replace the O-rings on all the ports on all tanks.
      My inspection ports were all made by Beckson Marine, http://www.beckson.com . I think they call them “deck
      plates.” Beckson was quick and reasonably priced about sending new O-rings. To order by phone, call Cindy
      at 203-333-1412 to order.
      Good luck,
    • #70157
      patn
      Hi Barb
      Generally in our case, it isn’t the tank but rather the over fill that
      drips over the floor.. The overflow lines drain inside the hull. On
      our boat you can see the small tube coming off the tank through the
      forward cutout (along with the bigger fill tube).
      One way to check (once the floor is dry) is to fill the tank via the
      inspection port so you know you haven’t overfilled and then see if you
      get water ..
      – pat
      (ps call if you want to walk through it .. 608-233-4341)
      svtopaz wrote, On 6/15/2008 7:26 AM:
      Barbara
    • #70158
      I had this same problem on my bow tank; the inspection port leaked. I
      had to replace the whole port as it has somehow warped and a new o-ring
      still did not make the seal.
      Silver Heels wrote:
      Barbara,
      Good luck,
    • #70159
      Hi All,
      My tanks vented into a false bulkhead forward (just aft of the sink) in the v-berth area and in the hanging locker in the v-berth. Clearly, overfilling the tank would result in a lot of water going everywhere.
      The inspection ports were clear plastic Beckson deckplates. They are not designed for internal pressure. Consequently, by overfilling, you cause the o-ring to leak. I replaced them with stainless steel access plates. You can read about it somewhere on my blog http://thesailinglife.blogspot.com. If anyone is interested, I'll find the link.
      I've moved the vents to the bilge, but have come up with a better idea with a loop in the vent and drain to bilge – running the lines to the deep part so I don't fill up all the dips and bumps around the mast.
      A better way would be to vent into a sink, but that's too difficult.
      On Sun, Jun 15, 2008 at 11:30 AM, Pete Dubler < ([email][/email])> wrote:
      I had this same problem on my bow tank; the inspection port leaked. I had to replace the whole port as it has somehow warped and a new o-ring still did not make the seal.
      Silver Heels wrote:
      Barbara,
      your boat also has these check them for leaks around the screw-out center piece. If they're leaking,
      Good luck,
    • #70160
      I’m hoping the new O-rings in my Beckon Marine inspection ports will stand up to a topped-off water tank, but have not tested them yet. Is anyone out there able to overfill your boat’s water tanks without the Beckson inspection port seals leaking, or are they universally inadequate?
    • #70161
      Hi Tor,
      I didn't realize everyone had them – they were so shoddily installed that they leaked all around and through the o-ring. They were clear or smoked. The long and the short of it is that they're not designed for internal pressure and I'm surprised Pearson put them in.
      I've had '78 boats with sealed water tanks. You can't scrub them, of course, but you can shock and clean them chemically.
      I had no idea Pearson did that.
      On Sun, Jun 15, 2008 at 4:42 PM, Silver Heels < ([email][/email])> wrote:
      I'm hoping the new O-rings in my Beckon Marine inspection ports will stand up to a topped-off water tank, but have not tested them yet. Is anyone out there able to overfill your boat's water tanks without the Beckson inspection port seals leaking, or are they universally inadequate?
    • #70162
      svtopaz
      I have a lot of good info here. Bob I like the stainless port idea. I am pretty sure it was the inspection port that is the problem, though I am thinking of changing the vent line also. It is the same as yours, it goes through the bulkhead, just aft of the sink up a foot or so,
      then back down to the bilge. It looks pretty grunchy. So again thanks everyone.
      Barbara
    • #70163
      Regarding the vent line, mine goes up a few feet above the tank and then
      loops back down draining into a larger diameter piece of tubing and then
      down into the bilge. The small tube draining to the larger tube creates
      a simple vacuum break to prevent siphoning and makes sure the overflow
      goes into the bilge. Also, since the drain loops so high, the tank will
      not drain when the boat is heeling steeply.
      Robert Fine wrote:
      Hi All,
      everywhere.
      http://thesailinglife.blogspot.com. If anyone is interested, I’ll
      find the link.
      I’ve moved the vents to the bilge, but have come up with a better idea
      deep part so I don’t fill up all the dips and bumps around the mast.
      A better way would be to vent into a sink, but that’s too difficult.
      Silver Heels wrote:
      Barbara,
      http://www.beckson.com <http://www.beckson.com> . I think they call
      them “deck
      Good luck,
      http://www.SilverHeels.us <http://www.SilverHeels.us>
    • #70164
      Here is the link to Bob’s post on replacing the water tank access panels. Looks like a nice fix.
      http://thesailinglife.blogspot.com/2007/08/beautiful-solution.html
      s/v Deep Playa – Pearson 424 #152 | http://www.DeepPlaya.com
    • #70165
      Hi Peter,
      That's an excellent idea – and far less expensive than a vented loop. I've been thinking pretty strenuously about whether to vent the loop or not, since the vent doesn't go appreciably into the tank, I'm not worried about siphoning in or out.
      On Sun, Jun 15, 2008 at 8:14 PM, Pete Dubler < ([email][/email])> wrote:
      Regarding the vent line, mine goes up a few feet above the tank and then loops back down draining into a larger diameter piece of tubing and then down into the bilge. The small tube draining to the larger tube creates a simple vacuum break to prevent siphoning and makes sure the overflow goes into the bilge. Also, since the drain loops so high, the tank will not drain when the boat is heeling steeply.
