Forums › General Discussion › Water Tank Vent
- This topic has 4 replies, 3 voices, and was last updated 12 years, 11 months ago by
Tor.
November 24, 2013 at 6:40 pm #68821
Miss Kathleen
ParticipantHi All,
Just replaced a portion of the bulkhead around the chain plates and also the floor area inside the forepeak locker on the port side.
At the same time I crack tested all the chainplates – and they were good, however, on reinstallation one of the heads of a bolt broke off. Result – new bolts!
Generally the sealing around the plates was good and I took the opportunity to fill the area around the chainplates with epoxy. No more water will enter the deck area around the chainplates.
It was hard to believe that a leaking chainplate could result in so much damage. In the end, on evaluation, it was another item that caused the damage.
The water tank vent pipe fitting.
To replace the portion of bulkhead I had to remove quite a few items, and one of these was the water tank vent – which in my case is simply a pipe fitting jammed into a hole in the deck with some silicon for sealing. This is then covered with a small piece of teak to prevent salt water entering under rough conditions.
I guess that over the years when the tanks were filled the water would come out the vent pipe and then straight onto the bulkhead and then drain down to the bilges inside the forward locker.
I am going to re-route both port and starboard overflow pipes to the upper anchor locker. Easy to monitor when filling, and no worries about salt water entering the pipe.
Maybe you folk have already addressed this issue, but if not, it would be prudent to do a check on the vent fitting.
Cheers
Dennis
November 24, 2013 at 10:04 pm #80363
ModeratorI moved all my vents to the bilge because I was tired of getting my clothes
wet every time I filled my tanks. Be careful about moving the vents to the
deck because the fiberglass tanks are not rated for much pressure – moving
the vent 2-4 feet above the tank results in a pressure of 1.5 to 2.0 psi.
They could fail.Bob
On Sun, Nov 24, 2013 at 1:40 PM, Miss Kathleen wrote:
Hi All,
the floor area inside the forepeak locker on the port side.At the same time I crack tested all the chainplates – and they were good,
new bolts!Generally the sealing around the plates was good and I took the
water will enter the deck area around the chainplates.It was hard to believe that a leaking chainplate could result in so much
damage.The water tank vent pipe fitting.
under rough conditions.I guess that over the years when the tanks were filled the water would
down to the bilges inside the forward locker.I am going to re-route both port and starboard overflow pipes to the upper
water entering the pipe.Maybe you folk have already addressed this issue, but if not, it would be
prudent to do a check on the vent fitting.Cheers
Dennis
November 25, 2013 at 11:07 pm #80364
Miss Kathleen
ParticipantBob,
Good point. The vents are currently located in the coaming and I was thinking of moving the outlet to the anchor locker.
On second thoughts your option returning the outlet to the bilge, maybe with a siphon break, will be a better idea, and simplet to install.
Anything is better than overflow water at the bottom of lockers, over clothes, or into the bulkheads.
Cheers
Dennis
November 26, 2013 at 1:12 pm #80365
ModeratorLest you think that the 424 is the only Pearson to vent water tanks into
blind spaces or clothing drawers, it’s not. The 35 and others did the same
thing.The idea was to have the cushions off and look through the inspection plate
to ensure the tanks didn’t overflow. But when you need to remove 8
cushions and pull out a bunk the sense of that is lost.I put steel plates over the holes and made sure the vent was only high
enough to keep the tanks from emptying while heeled. About 18″. That
minimizes the tank pressure. Also it gets the bilge washed every so often.Bob
I’m not being terse. This is from my cell phone and I detest typing on it.
On Nov 25, 2013 6:07 PM, “Miss Kathleen” wrote:Bob,
thinking of moving the outlet to the anchor locker.On second thoughts your option returning the outlet to the bilge, maybe
with a siphon break, will be a better idea, and simplet to install.Anything is better than overflow water at the bottom of lockers, over
clothes, or into the bulkheads.Cheers
Dennis
November 26, 2013 at 1:39 pm #80366
ParticipantMy water tank vents have never been a problem because I
dare not fill my tanks. That’s because I have never
managed to adequately seal the inspection ports. I
installed all new O-rings in the plastic ports Pearson
put in, but they still leak when the tanks are full. Of
course, I could seal those holes so nothing ever gets
through them, but I need easy-open inspection ports for
periodic cleaning and, well, inspecting – checking
water levels and dirt accumulation.My solution has been to avoid filling the tanks to the
brim. I watch/feel through an open inspection port when
taking on freshwater and stop when the level reaches
about an inch below the tank top. It’s a modest PIA,
but it works. Of course, this way the tank vents never
come into play at all, so I haven’t bothered to
rearrange them.Has anyone found a quick-opening water tank port cover
that doesn’t leak?Tor
