Forums › General Discussion › Westerbeke 58 Alternators
Viewing 10 reply threads
    • #68378
      I was checking out my alternator and I was wondering if any of your W58 owners have high output alternators and if so which ones have you been happy with.
    • #77416
      Good morning Patrick-
      Actually, we have two HD alternators, a 100 amp Balmar replacing the original, and a 120 amp Ample Power where the refrigeration compressor used to be. One VR drives them both. Two smaller alternators are much cheaper than one big one. Two pulling in approximately opposite directions minimizes side loading on the engine.
      It works well. We have seen 140 amps into partly depleted bank of 8 GC batteries, not really stressing either alternator. Pretty good redundancy esp. since we have another similar VR driving the alternator on the Kubota which is a simple change the plug exchange.
      A few problems to avoid. Original alternator bracket on the W-58 is barely robust enough for the bigger load. The bolts are not. Replace them with grade 5 or 8 bolts. Do not use stainless, they will break. Watch the wiring harness harness that they give you with Balmar. It is not marine quality and connections will corrode and break, esp. at alternator. Use heavy power and ground cables and run them directly to battery bank.
      About the only thing I’d do differently is use slightly bigger pulleys on the alternators. We used 2″ with double belts. I wanted to be able to spin the alternators pretty fast at idle, but 2.5″ or 3″ would work fine and be easier on the belts.
      Clairebuoyant, #132
    • #77423
      No problems with a balmar on a westerbeke 64 after 5 years
      Sent from my droid….
      with.
      Deep Playa, #152 http://www.DeepPlaya.com
      http://server5.websitehostserver.net/mailman/listinfo/maillist_pearson424.org
    • #77429
      So glad you asked…
      I have two of the high output Ample Power PT-24 (aka 4024) 136 Amp
      alternators left over from my engine swap out. One is an unused spare.
      Both have double belt pulleys. Also have some extra brushes and
      bearings to go with these. What is nice about these, besides the output
      and the fact that they are direct “drop-ins” for the original
      alternator, is that they use standard Delco cases so they are recognized
      anywhere and the parts, like bearings, are cheap if you ever need them.
      I wish I could use these on my new Beta but the foot conversion (new
      case) and pulley swap out is just not worthwhile. Here is the website:
      http://www.amplepower.com/products/alternators/index.html These sell
      for $549 new. Contact me directly and make me an offer I can’t
      refuse… BTW, I love the Ample Power stuff. I have two of their smart
      regulators; one for the engine alternator and one to control my 6HP
      scuba compressor/12V generator with 200 AMP alternator (which is
      physically way too big for the W-58.
    • #77431
      Thanks everyone.. I’l l have to sort out my plans.. I had not really paid
      attention to my alternator seemed to be working fine , but while I was
      changing the oil I decided to jot down the make and model… Leece Neville
      8RG2064 and it says its output is 12V @ 4AMPs… unless I”m not
      understanding something…
      I am utterly dismayed how I’ve been able to be off the shore power at the
      dock at all.
      On Sun, Jul 17, 2011 at 5:09 PM, Pete Dubler wrote:
      So glad you asked…
      http://www.amplepower.com/**products/alternators/index.**html These sell
      with.
      https://pearson424.org/mailman/**listinfo/maillist_pearson424.**org
      maillist@server5.**websitehostserver.net
      http://server5.**websitehostserver.net/mailman/**
    • #77432
      Pat
      That was the regulator that you got the model number from.
      Date: Mon, 18 Jul 2011 00:05:51 -0700
    • #77433
      A multi-step alternator regulator (like those from Ample Power) with a
      large alternator makes all the difference. Alternators with built-in
      regulators just don’t optimize the charging of large battery banks and
      don’t optimize to battery type.
      The “Living on 12-Volts With Ample Power” is worth reading. Also, the
      Ample Power website has links to many articles which basically cover the
      crux of that book. http://www.amplepower.com/tech_docs/index.html
      dock at all.
      So glad you asked…
      with.
    • #77434
      Several years ago I added a Behr 150 amp alternator to my 58–with two belts. It was dedicated to the house bank of four flooded golf cart batteries and the windlass battery. The old automotive alternator was then dedicated to my 8D starting battery. These two worked well to keep all our batteries charged up with engine running time limited mostly to that needed to anchor at night and weigh in the morning. I also had a Xantrax 40 amp shore power smart charger which I used to “equalize,” i.e., de-sulfate the batteries once a month.
      Norris Larson, PO of Easy Reach, Hull # 206
      — On Sat, 7/16/11, Patrick_DeepPlaya wrote:
    • #77561
      dock at all.
      Finally found a sticker on my alternator. It’s a Leece-Neville 8MR2198L 65Amp Alternator….
    • #77562
      You should replace it with a heavy duty 100 amp (at least – if you only have one belt) and a 3 stage external regulator.
      UNABATED
      — On Thu, 9/1/11, Patrick_DeepPlaya wrote:
    • #77571
      Patrick,
      Its a 65A alternator.
      http://www.prestolite.com/pgs_products/specs.php?item_detail_id=26470&item=8MR2198L&product=ALTERNATOR
