Forums › General Discussion › Westerbeke sprung a leak
Viewing 2 reply threads
    • #68766
      calicojack
      Hi Guys
      I have an engine problem on my trusty (or crusty) ‘ole Westerbeke. One of the head bolts is seeping oil around the top of the bolt. I’ve heard everything from I have a blown head gasket to I just need to re torque the head. Anybody experienced this?
      Many Thanks/ Jack
      Calico Jack
    • #79983
      Jack,
      Gasket ,…. You come from a great yard. I am sure they can take a look at it.
      On Aug 2, 2013, at 3:31 PM, “calicojack” wrote:
      Hi Guys
      Many Thanks/ Jack
    • #80030
      Jack;
      I have been trying to rebuild the head on a W63C for the last year after I dropped the exhaust valve in the #1 cylinder. I had to go to China for a replacement cylinder head. So far I have had the head totally rebuilt and have installed the head three times. I am getting close to having it done (maybe???).
      You can try to re-torque the cylinder head bolts, but I suggest that you follow the tightening pattern required for the head. A service manual for your engine may be available from Westerbeke web site for free (believe it or not) or any trusty engine mechanic will explain the required pattern of tightening. I would also recommend re-tightening all head bolts. You MUST use a calibrated torque wrench to re-torque the head bolts. The torque specifications will be in the service manual (about 85 ft-lbs).
      If this does not work, theny you will have to replace the head gasket. You could do this yourself if you have the proper skill set and tools or a diesel mechanic will be required. If it is an old engine then you might also have the head re-built.
      Good luck
      Steve
