Forums › General Discussion › Westerbeke w-60
- This topic has 6 replies, 6 voices, and was last updated 14 years, 7 months ago by
Seawater.
March 9, 2012 at 9:15 pm #68523
When I pull this giant engine and move it forward to remove the fuel tank, can I rest it on it’s belly (oil pan) or do I need to block under the engine mounts to prevent tragedy?
-Adam
March 9, 2012 at 9:29 pm #78282
ModeratorYou should be able to put two lengths of 4 x 4’s under the mounts for it to
sit on.Bob
-Adam
March 9, 2012 at 10:54 pm #78283
Seawater
ParticipantYou probably should block it, but I have a spare one in the garage that has been sitting on its belly for over a year. It has even been run that way. But without a spare, if you did crack it finding a replacement might be a problem.
March 10, 2012 at 12:22 am #78284
ParticipantI would support on the mounts with some 4x4s
-Adam
March 11, 2012 at 3:00 am #78285
RichCarterParticipantI used refrigerator rollers, available at most home goods stores. I lifted the engine using a cable winch and slid 2×6 boards under the engine mounts. Used the rollers to slide the engine forward and out of the way. Under no circumstances shuold the engine sit on its pan.
March 11, 2012 at 4:04 pm #78287
ParticipantThx fellows. I am going with the general gist, that being, “under no circumstances,” rest the big girl on her belly.
March 20, 2012 at 2:52 am #78325
Seawater
ParticipantNow that I think of it, the engine rode here on its own pan all the way from Virginia to Boston in the back of a commercial pick up truck, and I don’t know what treatment it got being moved from the yard to a friend’s garage for storage while awaiting transport here. The guy who did move it into the truck and brought it here is kind of a roughneck so it probably got slammed around some. So if you do have to rest it on the pan, if I were you, I wouldn’t get too alarmed.
