Forums › General Discussion › Wetted surface area
Viewing 12 reply threads
    • #68127
      My records show a spec of 372 sq ft for the wetted surface area– pretty
      close to Rich’s estimate!
      Rodd Leeds
    • #75974
      Rodd
      That comes out to precisely 5 gal for three coats, or 1.66 gal/coat. If I had it to do over again, I’d mix precisely that much so that I knew I had 4 mils per coat.
      Its difficult to mix partial batches but doable. I mixed half-gallon batches by marking a mixing stick with notches so I could measure how much I poured out. You have to mix the product parts before pouring the stuff out so its a pain. I didn’t try a paint-shaker and wonder if it would work. The part-A stuff is pretty thick. I don’t know if a shaker would mix it. One of these days I’d like to get one anyway. I brought my bottom paint to the local hardware store. They put it on their shaker but the first can leaked. They use plastic lids now and the new shakers don’t clamp the lid down tight enough.
      http://www.harborfreight.com/pneumatic-paint-shaker-94605.html
    • #75975
      For me, I used 4 gallons total which gave me 2 coats overall and a 3rd coat at
      the waterline. It’s the waterline that needs that 3rd coat…and you save $250
      by not having to buy a 5th gallon. ….I used Trinidad SR red, by Pettit. I read
      someplace that the color red is the best for copper based antifouling paint as
      it does not interfere with the copper.
      my 2 cents worth…
      Original Message —-
    • #75976
      I used the Trinidad SR also – 4 cans, 2 coats with a 3rd around the waterline. Held up well for the most part. Peeled a little in the same spots it always peels…worn on the leading edges. but not a big issue with me. I want to switch to RED from the Black.
      Question – Can I paint over the black ( after roughing it up a little) with the RED. The boat is and will be out of the water for a few months….. Or do I have to start from scratch…..?
      — On Tue, 9/7/10, Joseph Steiner wrote:
    • #75977
      Alan,
      I can not speak from experience because I never painted over black, but as a
      chemist I believe you should not have any problems since the polymers are the
      same and black pigment should not affect adhesion. You do need to sand before
      applying fresh paint. Also, in case you did not know this, since you are on the
      hard, paint within 48 hours of splashing the boat because sunlight and air will
      oxidise the surface and reduce the effectiveness of the paint.
      Joe
      Half Moon
      Original Message —-
    • #75978
      ALAN: You can paint hard epoxy over hard epoxy following a light sanding,
      regardless of the pigment.
      FYI,Ablative bottom paint can be applied over epoxy as well after sanding
      and cleaning, but NEVER epoxy over ablative.
      Have fun!
      BILL, WEST MARINE, str#187, Deltaville.
      ~~(__~~ (_~~~fair winds~~ (_~~
      Capt. William Tice, USCG Master, 100 Ton
      In a message dated 9/8/2010 9:21:45 A.M. Eastern Daylight Time,
      writes:
      Alan,
      a
      the
      before
      on the
      will
      Joe
      Half Moon
      Original Message —-
    • #75981
      Here’s another, more integrated paint shaker I’ve used aboard Silver Heels.
    • #75982
      Last time I checked, the red Petit Trinidad antifouling paint contained 75%
      cuprous oxide, a higher amount than the other colors of the same brand, and
      higher than any other commercial bottom paint I’ve found. But you pay for
      all that copper.
      My last haul-out I scored a 5-gallon can of red International brand
      antifouling paint made for commercial vessels, with something like 47%
      cuprous oxide content. A used boat gear place in St. Augustine was buying
      and re-selling the stuff cheap. The catch was the paint was about a year
      beyond its expiration date. I contacted the manufacturer about the possible
      problems of using their bottom paint so outdated and decided it was worth
      taking a shot since I was only paying $200 for the 5 gallons. I think I got
      about 3-1/2 heavy coats out of it – or was it 4-1/2? – and it turned out to
      be a good gamble. A year and a half later it’s still holding up well.
      Moral of the story: check your local used boat gear stores for deals on
      bottom paint. That’s doubly applicable to you guys who dry-dock your boats
      every winter. Your antifouling only has to last 6 or 7 months so you don’t
      need the best of the best.
    • #75983
      I have the same generator. Cute…
    • #75984
      One would think that we owners in norther waters would have an advantage when it comes to bottom paint. It doesn’t seem to work that way though. We get a lot more daylight during the summer months than those in lower latitudes and the cold water carries more dissolved gasses for bottom-growth to feed on. We can get quite rapid bottom growth in spite of our short season. I suppose that most of us have the advantage of having the boat out of the water each year for service.
      I’ve been using Petit ablative paint for many years now. I prefer the ablative paints because they don’t build-up and can last a few seasons. I usually touch-up the bottom paint where it needs it and add a coat each season up near the waterline. If the bottom paint looks think, I add a new coat. I have a diver clean the bottom a couple of times each season to keep up with the slime.
    • #75985
      Interesting. I always assumed bottoms sprouted growth faster in the tropics (though I used to earn extra money when I was a kid scrubbing boat bottoms in the LI Sound in Larchmont). Live & learn.
      Silver Heels recently got a free bottom cleaning when I sailed her up the Rio Chagres, a jungle river near the Panama Canal. Actually, there wasn’t much growth on the bottom just then – I had dived and cleaned it a few weeks before – but there were lots of barnacle bases left from my stay in Cartagena harbor, where boat bottoms foul with extraordinary speed in the polluted harbor water. While we were up the freshwater river, not only did the bit of sea growth die and fall away in a day, but most of the remnant barnacle bases dropped off, too! A little green slime quickly started growing near the waterline in the river water, but that disappeared when we re-entered the salty sea.
      Are there any navigable rivers you can visit in the NE for a free, mid-summer bottom cleaning? I don’t suppose anybody careens their boat anymore, although I believe you’ve got enough tidal range up there to do it.
    • #75986
      Most rivers in the NE wouldn’t qualify as fresh because of large tidal ranges. The Hudson is tidal all the way to Albany and the St. Lawrence all the way to Quebec City, where the tidal range is 9 feet. One would need to go up the Penobscot, 9 foo range again, beyond the limits of navigability to get to realy fresh water. And speaking of pollution, one year a paper mill above Bangor had an uncorntrolled release of crap and boaters below Bangor complained of high barnacle counts. In the Caribbean there is little tidal range, a foot or so so river currents will keep salt out of areas above estuaries.
      Norris Larson, Easy Reach, #216
      — On Fri, 9/10/10, Silver Heels wrote:
    • #75989
      Both the Hudson and Connecticut Rivers as well as the Thames in New London
      will clean your boat bottom if you go far enough up. For the Connecticut
      River, it’s only about an hour up it. For the Hudson, it’s about 40 miles
      (Bear Mountain, West Point – that area) before you’re in essentially fresh
      water. The salt water being denser tends to stay deep. The Thames in New
      London needs about 10 miles before you’re mostly in fresh water.
