Forums › General Discussion › Where is your waste holding tanks ?
Viewing 14 reply threads
    • #67912
      svtopaz
      Where have people placed their holding tank? I am looking to put one in this winter and want ideas as to where to put it. I have an electric sans in the salon area (middle cabin sole).
      Barbara
    • #74876
      Barbara
      My 424 was originally fitted with a tank in the back of the main cabin hanging locker next to the midship companionway. I think it was in the back of that locker. It was later refit with an Electra-san under the cabin sole just forward of the bilge sump by the first owner. I relocated the electra-san to the head cabinet just next to the head pump. My thought was that short hoses would be easier to maintain and less odor. I’m planning to put a Y valve in and a small tank where it was originally located.
    • #74877
      I have a 28 gallon tank in the bilge behind the ballast. Pictures if you
      want them on
      http://thesailinglife.blogspot.com/2009/08/finishing-projects-holding-tank.html.
      Cheers!
      Barbara
    • #74878
      Lady Leanne has her tank just forward of the deep bilge. I believe that it’s the original position. The PO mounted a macerator just below the hatch located between the galley drawer cabinet and the midship companionway stairs. The macerator is abaft and above the tank.
      Lady Leanne (#135)
      Honolulu
    • #74879
      I mounted Navasana’s holding tank atop the encapsulated bilge, aft the mast step and accesible by via main bilge.
      Y valve inside the haging locker after the head allows discharge direct or to tank inlet.
      Y valve mounted under cabin sole directs to deck level pumpout or to macerator for direct discharge. We had a bit of a problem with oder in the hanging locker (aka stinky locker) seemed to get fixed when i upgraded vent hoses to sanatation hose. orignal installation used some left over fresh water hose I had kicking about.
      -Eric
      — On Mon, 2/1/10, kalinowski <> wrote:
    • #74880
      Hey Rube, can the poop really turn all those corners?
      want them on
      Cheers!
      Barbara
    • #74881
      I have taken up a big part of the sole in the saloon to glass in a new
      fuel tank. I calculated that I can get a 95 gallon tank in this space
      (between the mast and main bilge and 42 inches wide. So, if you want to
      cut out the sole, there is plenty of space for glassed-in tank. (I
      spent about 5 hours yesterday moving the wires and hoses out of the way…).
      Also, if you are interested, I have a new small holding tank that is the
      largest I could find that would slip through the bilge sole hatch and
      slide forward under the saloon with a tank gauge in it and fittings if
      you are interested. Also a macerator pump that has never seen the brown
      stuff and three-way valves. (I am going to switch over to a composting
      head). Also have an electro-san to sell.
      Barbara
    • #74882
      Whoa, you’re doing all that and haven’t leaked a single photo? quit holding
      out on us! 😉
    • #74883
      Unbelievably, yes, it can – it’s like a waterpark ride for poo.
    • #74884
      LOL. While you are at it, consider the following for your toilet paper
      to complete the attraction:
      http://www.youtube.com/watch?v=5iIZpnBpTfU
    • #74885
      Absolutely classic. I wonder if it’ll fit on deck…
      On Tue, Feb 2, 2010 at 10:16 AM, Pete Dubler <> wrote:
      LOL. While you are at it, consider the following for your toilet paper to
    • #74886
      It’s a hole… about 44 x 32″ That big red hose is the deck was
      line. Runs from the aft end of the aft berth where there is a thruhull
      to the pump, under the galley sink, to the deck wash fitting on the port
      side of the deck beside the anchor locker. Pretty silly… I am going
      to move the pump to under the v-berth sink and use the sink drain as the
      source of sea water (tee the fitting).
      See the vertical wall in the fiberglass, just behind the mast step?
      That will be the front of the tank. The aft edge will be just in front
      of the flat area in front of the deep bilge. This will leave me a step
      for getting down into the bilge. My new fuel valve/filter/polishing
      system(with a drip catch pan) will mount on one side there (pictures
      later) and the valves/filters for the watermaker on the other side. I
      am debating about topping the tank below the 2×4’s or coming up a few
      inches on either side. There will be an access hatch for the fittings.
      I will add another button to my TankTender for use as the tank gauge.
      More fun on the Front Range…
      On 2/1/2010 10:29 PM, Patrick Walters wrote:
      out on us! 😉
    • #74887
      On Easy Reach, plan “A” below decks (2 full heads, no midships companionway), I installed a rectangular 25 gal tank underneath the aft forward facing setee. It works, but is angled in such a way that the outlet, which is outboard, is higher than the inboard end of the tank. Consequently, it never gets completely emptied. If I were to redo it, I would insert a downward pointing elbow into the outlet opening so it would pick up more of the effluent.
      Norris Larson
      — On Tue, 2/2/10, Pete Dubler <> wrote:
    • #74888
      photo was stripped from posting… I am not sure how to show it.
      thruhull to the pump, under the galley sink, to the deck wash fitting
      on the port side of the deck beside the anchor locker. Pretty
      silly… I am going to move the pump to under the v-berth sink and
      use the sink drain as the source of sea water (tee the fitting).
      front of the flat area in front of the deep bilge. This will leave me
      a step for getting down into the bilge. My new fuel
      valve/filter/polishing system(with a drip catch pan) will mount on one
      side there (pictures later) and the valves/filters for the watermaker
      on the other side. I am debating about topping the tank below the
      2×4’s or coming up a few inches on either side. There will be an
      access hatch for the fittings. I will add another button to my
      holding
      out on us! 😉
    • #74889
      patn
      sigh … I’m still working on why it stripped.
      In the meantime – you can view the photo at:
      http://drop.io/pearson424
      Any photo can be sent to:
      – pat
      Pete Dubler wrote, On 2/2/10 5:58 PM:
      It’s a hole… about 44 x 32″ That big red hose is the deck was line.
      Runs from the aft end of the aft berth where there is a thruhull to
      holding
      out on us! 😉
