Forums › General Discussion › Winter cover
Viewing 1 reply thread
    • #67125
      Depending on the type of winter you get there, how
      much money you wish to pay and how long you figure
      your going to be there.
      I had an expensive cover made for my 30 and it lasted
      only a few more years than I get with a well built
      ridge pole and tarp.
      I build a ridge pole using a series of saw horses 6
      feet apart down the middle of boat (2×4’s). Pad these
      with scrap carpet. Ribs also of 2×4’s, cut to match
      the angle (depending on the height), go from the
      center to the toe rail (pad these also). Space these
      about the same as the stanchions. Total wood bill was
      around 100. and lasts for years (if you dont throw
      them off the boat in the spring).
      DON’T BUY THE BLUE TARPS! The gray ones (black on the
      other side) are much better and worth the money.
      Also, DON”T USE THE GROMMETS! They will pull out in
      the first good wind that gets under the cover.
      I find nice round stones about an inch in diamenter.
      put a stone behind the tarp where you want to put a
      tie down, Twist the tarp around the stone and then tie
      the rope around the outside.
      I got 4 years out of the last tarp. Tarp costs 150.
    • #70493
      I agree the grey tarps hold up to the UV better. EMT tubing also works well for ridge poles and support. David Thompson
      To unsubscribe, e-mail: ()  ()
      For additional commands, e-mail: ()  ()
