Viewing 6 posts - 1 through 6 (of 6 total)
  • in reply to: stern rail #224742
    424 person
    What I did with stern rail was to cut in half and move to shear. Added 5” to outboard legs and added third leg to inboard end. Ended up with 20” gap and cleaned up cockpit coamimg. This spring will be cutting transom open at seat level to create easy access to stern ladder. Needed to core area where ladder is through bolted, since 424 was never meant to have a structural transom. Also be attaching backstay to transom, this opening up cockpit coaming even more.
    Also moved all stantion bases to shear opening up walkway. These I glassed knees underneath and split jib tracks. Just trying to modernize an almost 40 year old boat.
    in reply to: stern rail #224741
    424 person
    Many years ago I met a couple that had cut-out the aft section of the cockpit, making his 424 into a walk-thru. If you have enough time and money, you can do just about anything. I can’t guess what this would cost.
    It would be fairly reasonable to just cut out part of the push-pit and add a permanent transom ladder. More than that and you’re in for serious bucks. If you cut the push-pit, you may have to put a gate in for insurance purposes, a good idea in any case. I wouldn’t even consider cutting out part of the transom. I’ve taken waves over what’s there already.
    in reply to: Testing Restored Emails #220788
    424 person
    Got it
    in reply to: Hooka Rig Available #220559
    424 person
    Still available?
    Chris
    Sailvt2000@yahoo.com
    in reply to: Used Sails P424 Ketch #220557
    424 person
    Are any of these sails still available?
    Chris
    sailvt2000@yahoo.com
    in reply to: How do quit? #220555
    424 person
    Actually I just joined a week ago. Perhaps you emailed by mistake. I have been waiting to be approved.
    Chris Morgan
