figie47gmail-com
ParticipantMadsailor; Please get in touch with me re: W58 engines.
email me at figie47@gmail.com or im to 917-689-9246 (my phone does not accept calls from unknown numbers)
Please leave contact info and location of engines and idea of what you may want for the best of the engines.
I’m in Williamsburg, VA.
Best regards
Ron Feigenbaum
S/V Patricia Bessfigie47gmail-com
ParticipantRich and Sherry
We will be based in Deltaville this coming season. As us to you list.
Jan and I would love to meet other 424 owners in the area.
Ron & Jan Feigenbaum
ParticipantCheck out the Hamilton Ferris PM 125
Works with a smart regulator and a single belt. Make sure the pulleys are in alignment.figie47gmail-com
ParticipantJan and I would like meet up in or around Crown Point first weekend in June.
I can be reached at figie47@gmail.comfigie47gmail-com
ParticipantHi All,
We are based in Yorktown, VA and will be heading to Port Washington, NY, LI the last week of June. Will be spending a few week in P.W. before sailing down the sound to end-up in Newport, RI first weekend Aug. for Jazz Fest. Love to meet-up with other 424 owners anywhere along the way.
Ron Feigenbaum
S/V Patricia BessAlso looking for crew to help me sail back to Yorktown end of Aug. via. outside.
figie47gmail-com
ParticipantWell, I found the maker of my prop shaft lock.
SeaAir,Inc / Sarns Machine
Raymond, ME
The “PropLock 2” was made in 1982 and as best as I can tell, the company is long gone.Today I took the pads to a local machine shop and they will recreate them for about $100.That’s better the having to buy a new locking device.
Thanks everyone for you input. One more project under control.
Ron
ParticipantJanuary 21, 2017 at 12:44 am in reply to: What kind of batteries are you using and where are you buying them? #222463figie47gmail-com
ParticipantSV Patricia Bess came with 3 Interstate 4Ds, Two starboard (house), One stern (starting).In the spring of 2016 I replaced them with 3 Universal Power UB-4D (from China), tied together to make up the house bank 600 Ah. I added a Costco group 42 under the berth next to the started motor, as an independent cranking battery.
The batteries are switched to hook the house to the starter if needed.
I have a Honda 2000 generator to charge house bank if i’m on a mooring for any amount of time. All four new bateries cost about $1100. I’ll let you know how this set up works out in a few years.
Ron
SV Patricia Bess #218figie47gmail-com
ParticipantPrior to owning my 424 I owned a Pearson Alberg 35.The sea cocks were bolted on with no mushroom through hulls, just the solid glass core exposed. The bolts were countersunk into the hull and the nuts were on the inside.The bolts would rot a way and the sea cocks stayed on by wishful thinking and luck.Bronze or plastic mushroom through hulls screwed into matching sea cocks is the way to go.Bolting would put the heads of the bolts to close to the mushroom head.I enjoy reading everyone comments on the up keep of the fleet.RonS/V Patricia BessĀ#217 -
