Bryan Bywalec
KeymasterJuniper is a plan C ketch. Not sure if fridge sizes varied between boat layouts.
Is there a Plan C Ketch? I thought they were all cutters. Do you have the galley to starboard? Just curious.
We have a plan C and a “SEA FROST BD 12 with AEO” air cooled system and I don’t have any complaints although haven’t gotten to the energy audit part of the refit yet.
Bryan Bywalec
S/V Pelican, Hull 209
Siren Engineering, LLCBryan Bywalec
KeymasterHi Evan
An update for the Registry for Hull #69 please: owners are Bob & Lyn Hancox and the engine is a Westerbeke 71C.
Many thanks.
Bob,
I updated the registry. Is the boat still in Australia?
Bryan
Bryan Bywalec
KeymasterCan you describe your main vs auxiliary fills? I hate the location of our plan C’s fill and am thinking about reworking it. Wondering what you are doing with your two fills.
Bryan Bywalec
KeymasterHey Rock,
You might have more luck if you post in the General Discussion section of the site.
To answer your question, almost any commonly sold automotive diesel starting battery will work. The manual is silent on sizing. Common automotive diesel engines are much larger and can be started easily. That being said, it is always nice to size the start battery as an emergency reserve so up-sizing is common and a matter of personal preference.
AS for the windlass, I highly recommend just biting the bullet and running large diameter wires from your house bank to the windlass. It is a waste to carry around a battery in the bow to save money on wiring when you could then use that battery to buffer the amp hours you are drawing from the house bank. This is especially true considering you probably only run the windlass when the engine is running.
Bryan Bywalec
KeymasterSilver Heels (Hull 17) has been purchased from Tor by: Eric Palm, 155 N. Harbor Dr., 3711, Chicago, IL 60601
I updated the registry. Congrats! Let me know if you change the name or the homeport in the future.
Bryan Bywalec
KeymasterHi there,
I need the dimension for the height to mount my attachment for the stay to the mast.
The sloop sail plan drawing on the site lists that it applies to only hulls 1 through 205. Perhaps that is when they changed the deck mold for the sloop.
The J dimensions, bow to front of mast, of the Ketch is 15.75 ft. For the Cutter it is 18.20 ft. According to my reverse engineering of the cutter GA drawing, the staysail attaches 31.65 ft above the deck at the mast on the cutter.
The Plan C has a different interior bulkhead layout than the Ketch or the Sloop so the deck attachment point may need to be investigated. I believe the bulkhead on the Ketch is farther aft and if the mast is farther forward it might cause the sail to be super tall and skinny if you use the cutter dimension.
If you can measure the J dimension of your boat and propose a place to attach it on the deck I think we can narrow down a proper height.
Where do you intend to attach it to the deck? It needs to be a strong point like a bulkhead or you’ll have to add a rod to hold the connenection down. My cutter also has check stays to prevent the mast bending forward at the staysail connection.
The drawing on sailboatdata.com actually shows two mast locations for the Plan A so you can get a sense of the difference in the attached picture.
-Bryan
Bryan Bywalec
KeymasterHello Scott,
Thanks for pointing out that the cutter plan is actually the sloop plan. I have been reorganizing the data on the site and didn’t catch that… I’ll look in my documents to see if I have the actual sail plan. I have a Plan C so if you need measurements I can take them from the actual boat too. I have to go up the mast this weekend anyway.
My wife and I have been working on CAD drawings of the Plan C so we can always make one from scratch if no one has one.
Bryan
Bryan Bywalec
KeymasterDoing some analysis on the Owner’s Registry it would appear that up to hull 125 had Westerbeke 60s, hulls 140-187 had a mixture and post hull 189 almost everything was a 58. However these are human reported stats and quite incomplete so take them with a grain of salt. The W58 is a good bit shorter and lighter according to Westerbeke’s website.
Our boat has a W58 which is currently humming right along but if she were to give up the ghost I’d also probably look at a Beta with Yanmar as a close second.
Bryan Bywalec
Siren Engineering, LLC1 user thanked author for this post.
Bryan Bywalec
KeymasterDoes it have a v-drive? I believe that the 424s have 1:1 transmissions but a reduction gear in the v-drive.
Bryan Bywalec
KeymasterHi Evan,
I am the proud and happy guy owned by New Hope, a Ketch rig, bought last November 2017 in Barcelona. Hull N° 75.
We organize community sailing activities and navigations with our Barcelona Balearics sailing Association.
In the owners list in the site it looks like New Hope was previously based in Seattle.
Does anyone has any idea of the story of the boat, and how many previous owners when she was on your side of the Atlantic ?Thanks and congratulations for this site,
Best
Giambattista Livi
Calle Comte Borrell 227
08029 Barcelona
Spain
navegacioavelabarcelona@gmail.comIt looks like she was documented in 1996 and already named New Hope at that time. The owner on that Certificate of Documentation was listed as JANANT INC. There weren’t any previous owner’s listed so they must have been the first to document her. There were no USCG contacts between 1996 and now so they never got boarded either! Trail goes cold as I couldn’t find any contact information for Janant Inc.
Bryan Bywalec
KeymasterCongrats on going all the way around! I’m in the process of reorganizing some of the static pages on this site and we decided it would be fun to have a 424 Hall of Fame. As the first person to post a circumnavigation announcement, y’all are the first inductee! Hopefully in the future the hall of fame will grow to be more than a list but for now check it out here: https://www.pearson424.org/424-hall-of-fame/
If you want to share more details about your circumnavigation shoot me an e-mail at bryan@iwouldsaygo.com. I’d be happy to interview you for the benefit of the handful of P424 owners currently refitting for extended cruising if you aren’t the blogging / writing type.
Anyone else reading this that has circumnavigated, feel free to drop me a line.
Bryan
Bryan Bywalec
KeymasterOur Boat #187 will be Forget Knot
List has been updated.
Bryan
Bryan Bywalec
Bryan Bywalec
KeymasterJohn,
I’ve started helping update the site and I went ahead and updated the owner’s list for hull 099. Take a look and let me know if I got it correct.
To anyone else who see’s this, I’m looking back to see what is currently out of date but if you have something you want updated feel free to reply here.
Bryan
Bryan Bywalec
KeymasterEwan,
I can help out with this and other tasks for the site if you are interested in a first mate. I run a few personal projects off of a home server and administer a few simple webpages. Nothing this complex but am happy to help.
As for Facebook I’ll look into making an additional dummy user to use as the entry point. Feel free to e-mail me at bryan@iwouldsaygo.com
Bryan
Bryan Bywalec
KeymasterThe reason I am changing to stainless is that the PVC wears through.
Out of curiosity how long did the PVC pipe last?
Bryan Bywalec
Siren Engineering, LLC -
