Viewing 15 posts - 61 through 75 (of 113 total)
  • in reply to: Non-skid coatings #223325
    Rick,
    We have experience with Kiwigrip but not on our 424. We loved it on our C&C…Easy to apply, very little prep work, you can easily vary the roughness depending on which area you're coating (less on cockpit seats, more on the side decks, etc.), and it's very durable. The only downside is the price. Plan on using more than you think to get enough coverage.
    We definitely plan on doing Revery this fall.
    in reply to: Non-skid coatings #223305
    Thom,
    If it truly is Kiwigrip, repairs are easy, even for us lazy types!
    Clean the area (denatured alcohol wipe down is what I do), tape the edges, slop on some new Kiwigrip, roll it with their roller cover (provided with each can purchased), pull the tape immediately, and you're done. The only caveat is that the color may not match due to UV fading. Me, I don't care…it's a cruising yacht, not a showpiece. ๐Ÿ˜€
    Hope that helped.
    Evanย
    in reply to: Electric Conversion #223057
    Dan and Ewan,
    We’re in the infancy of considering a repower. I know what I’d do if we go diesel, but would to pick your brains re: electric and the systems you chose. You up for some discussion? โ˜บ
    Thanks!
    in reply to: Sump Pump Location #223049
    Revery is being refit with the same setup as Rick has. The PO hadn’t used the shower in years, and had removed the pump. Shout out to Pete Dubler for recommending that simple solution to us (and finding a steal on a whale gulper pump for me).
    in reply to: Roller fueling #223044
    We have the same Harken as David’s on Revery. It came with the boat, looks older than Moses, but works fine. If, when we inspect the rigging soon, we decide it needs to be replaced, I doubt we’d go with Harken. Mostly because if cost, but also because it has an enclosed drum. But that’s not to say it isn’t a great unit…it’s a Harken after all.
    in reply to: AC side question #223042
    Well, that was easy. Grand total of 1 hour, including the run to WM (which, of course, didn’t have the bus bar I wanted). Now the circuit is (more) ABYC compliant and I can sleep better tonight. That’s an “after” picture…forgot to take a “before”. Originally, all the greens and whites ran to the bus on the left.
    Forgive the rest of the janky, yet original, wiring and connectors. They’re solid and I’m not ready for a complete rewire yet.
    in reply to: AC side question #223038
    And now to answer my own question (coffee and some more reading helped).
    ABYC says that neutral and safety grounding should ONLY be tied at the power source. Period. End of story.
    So it’s off to worst marine to get another bus bar so I can separate the two. Easy solution that will make things a tad more safe (he says hoping that the installer followed color coding).
    Anyone dissent? โ˜บ
    in reply to: Mast Pulpits – contact for fabricator? #223017
    Paul,
    Yep, still interested in the pulpits! ๐Ÿ™‚
    in reply to: Mast Pulpits – contact for fabricator? #223010
    Paul,
    Thanks again for heading this up! Question on the rails…is that per rail or per set? If it’s per rail, I’ll have to pass…which is ok since our teak ones are fine.
    Evan Morgan
    in reply to: Non-skid coatings #223009
    Hmmm…I replied twice to this thread via email and they didn’t post. So let’s try from the forum…
    Rick,
    We have experience with Kiwigrip but not on our 424. We loved it on our C&C…Easy to apply, very little prep work, you can easily vary the roughness depending on which area you’re coating (less on cockpit seats, more on the side decks, etc.), and it’s very durable. The only downside is the price. Plan on using more than you think to get enough coverage.
    Thom,
    Clean the area (denatured alcohol wipe down is what I do), tape the edges, slop on some new Kiwigrip, roll it with their roller cover (provided with each can purchased), pull the tape immediately, and you’re done. The only caveat is that the color may not match due to UV fading. Me, I don’t care…it’s a cruising yacht, not a showpiece. ๐Ÿ˜€
    Hope that helped.
    in reply to: [pearson424] Mast Pulpits – at last! #222967
    Paul,
    Thanks! And on a side note, I’d be interested in hand rails as well…if you’re amenable to me jumping on board.
    in reply to: Mast Pulpits – contact for fabricator? #222943
    Ben,
    The ball just started rolling yesterday with Paul's inquiry to the group. One of us (who want pulpits) will need to take the lead on updating the quote, etc.
    in reply to: Mast Pulpits – contact for fabricator? #222927
    Paul,
    I’ll do a deep search tonight, but I think the info is still here.
    If you’re willing to head this up, I’d like a set made as well…and I’m sure there are some other “new” owners that might be interested (or they should be lol)
    in reply to: Boat Insurance #222721
    Amen, Ken! We only had it as a condition of our partnership with the PO. After this year expires, we're done. Self-insured is the only way to go IMHO.
    in reply to: Boat Insurance #222716
    That's horrible!
    We go through Atlass Insurance in Cocoa…It's a Progressive policy, but at a competitive rate. About $1200 including Bahamas. YMMV of course.
    Contact info:
    KC Denick
    Atlass Insurance Group
    26 Oleander ST
    Cocoa, FL 32922
    321-459-9905
