Viewing 15 posts - 1 through 15 (of 50 total)
  • in reply to: Old Portlight Lenses #223127
    Jack Clarke
    Hi Tor,
    I don’t have any lenses for you but I used to take the hazing of the plastic lenses of my previous boat by applying Brasso brass to them. Just rub it on, let it haze and wipe it off. It will last for about three months.
    Good luck
    Jack
    Xanadu IV
    Sent from my iPad
    in reply to: Thickness and spacing of pedestal guard #222809
    Jack Clarke
    Hi Ryan,
    I’m on my boat and I just measured the binnacle guard.
    The measurements are;
    1″ thick tubing
    8 3/8″ between tubes
    9 1/2″ tube cantering
    I have a 1981 ketch.
    I hope that this helps.
    Jack
    Xanadu IV
    Sent from my iPad
    in reply to: V-Drive cooling #220916
    Jack Clarke
    I bypassed mine a couple of months ago and just did a motoring passage from Norman's Cay to Lake Worth FL.  28 hours of the trip was in very light winds and the v drive temp was 140* and no problems.
    Jack
    Xanadu IV
    in reply to: Removing Borg Warner Tranny #195582
    Jack Clarke
    We used short combination wrenches and got it out in two hours.  Five hours to reinstall.  We hired a very good mechanic in Dominica, W.I.  He only had one hand, he was amazing.  This was about 1 1/2 weeks ago.  We are now in St. Martin.  So far so good.  We bypassed the water cooling jacket and temp seems good.  We have about 13 hours on engine since then.
    Jack
    Xanadu
    in reply to: Stern ladder #168203
    Jack Clarke
    Hello all,
    Every time that I see similar type of boats like the 424's, I check out the swim ladders.  I receinty seen a boat in Martinique that a very similar transom to ours.  He had a fibreglass form made to replicate the stern with cut outs for the ladder steps.  It was hinged to swing down and was secured in place with cables and had a folding swim ladder on it.  When it was in the up position it had the boat name on it.  I didn't get a chance to get any pictures.  This is the best that I have seen so far for a swim platform.  For boarding our boat, we use a step hungnat the gates on either side.
    Jack
    Xanadu IV
    in reply to: Replacing port lights #168137
    Jack Clarke
    Hi Everyone,
    I replaced the six forward ports on Xanadu with NFM ports.  I ordered the tinted ones, about $20 more but it helps keep heat down and a measure of privacy.  The install went well and I didn't use their template. Just use lots of chalking.  The NFM ports tend to rust a bit under the rubber seal for the screen.  Getting the teak trim for inside is a good idea as well so that the outside lip doesn't stick out too far.
    For the four aft ports, I had taken the plastic lenses out and replaced them with tempered auto glass, tinted of course.  This was an easy, not too expensive replacement.
    Jack
    Xanadu IV
    in reply to: roller furling #78944
    Jack Clarke
    Just jumping in on this conversation, I have the Pro furl and one of
    the good points is that it’s an open drum. If you have a snarl or
    jam, it’s easier to clear it.
    Jack
    Xanadu
    On Sat, Nov 10, 2012 at 8:38 AM, Silverheels wrote:
    That sounds like good advice, Bob, and it may make my old Harken furler
    easier to operate. I’m still concerned about its age, which is
    uncertain. The PO may or may not have told me it was 15 years old when I
    bought the boat at the end of 2006, which puts it over 20 now. If I only
    sailed locally, I suppose I could keep using it until something breaks.
    But I go offshore and hang out in places where there is no indiginous
    word for “roller furler.” This replacement is more along the lines of
    preventative maintenance. Am I crazy?
    in reply to: maillist Digest, Vol 36, Issue 4 #78927
    Jack Clarke
    Got it with thanks,Jack ( Xanadu )
    On Sun, Nov 4, 2012 at 4:08 PM, Dawn Rodney wrote:
    Got it!!
    Dawn
    Sent from my Surfboard
    On Nov 4, 2012, at 12:00, “”
    wrote:
    Send maillist mailing list submissions to
    To subscribe or unsubscribe via the World Wide Web, visit
    or, via email, send a message with subject or body ‘help’ to
    You can reach the person managing the list at
    When replying, please edit your Subject line so it is more specific
    than “Re: Contents of maillist digest…”
    Today’s Topics:
    1. A test of a new spam filter (Robert Fine)
    2. Re: A test of a new spam filter (Robert Fine)
    3. Re: A test of a new spam filter (pat noordsij)
    4. Re: A test of a new spam filter (Joseph Steiner)
    5. Re: A test of a new spam filter (Elaine Patton)
    6. Re: A test of a new spam filter (Philippe Fontaine)
    7. Re: A test of a new spam filter (Silverheels)
    Message: 1
    Date: Sun, 4 Nov 2012 11:23:36 -0500
    in reply to: Electrical problems #78818
    Jack Clarke
    Hello everyone,
    The problems that I’m having are on the DC side of things. When running
    the engine all day, the house bank only gets up toabout 13.3 V, Then when
    I sut it down it drops to 12.9 and lower quite fast, in an hour or two.
    This happens when there is basicaly nothing on. The same thing happens
    after being hooked up to shore-side power or a generator.
    The starter battery is no problem @ 14.5 V.
    I had both alternators rebuilt in May, the house bank is charged by a
    Balmar 100 amp. and the start battery is charged by a 40 amp boshe. I put
    a new voltage regulator in for the Balmar in August. The start battery was
    new in April, the windlas/bow thruster battery new in June and the house
    bank new in August.
    In May I had a guy do some work on the boat and one of the thinggs he put
    in was a BEP Marine DC/AC meter and it tells you the charging rate as well
    the discharging rate and it shows something is drawing a lot of amps, and
    this is with everything shut off.
    I don’t know where or how to look for the problem.
    Bill I will give you a call tomorrow morning. I’m in Jackson’s Creek right
    in front of the marina.
    Jack
    Xanadu IV
    On Fri, Sep 28, 2012 at 7:56 AM, Robert Fine wrote:
    Hi Jack,
    Can you describe them? AC or DC? A particular item or a bunch of items?
    I’m sure there are people on the site that can give you some great ideas
    for tracking them down and dealing with them.
    Glad to see you’re making your way south! I wish I was there…
    On Fri, Sep 28, 2012 at 6:50 AM, Jack P Clarke
    wrote:
    Hi everybody,
    I have been experiencing some electrical problems for the last little
    while
    and I can’t track down the problem. The meter that I had installed back
    in
    May says that I an discharging power somewhere and I can’t find it. My
    electrical skills are very basic.
    Does anyone know of a good electrical guy in the Deltaville / Norfolk
    area
    that is reasonable. Or anywhere south of there, we are flexible as we
    are
    en route to the Bahamas. We will be in Deltaville most likely today and
    Norfolk by Sunday possibly.
    The internet coverage is patchy to non-existent at times so please bare
    with me on replies.
    Jack Clarke
    Xanadu IV
    in reply to: good mechanic #78721
    Jack Clarke
    The problems that I’m having are;
    1/ white smoke like steam coming out the exhaust
    2/ the hoses coming from the transmission cooler to the raw water pump
    are collapsing
    3/ I’m loosing coolant from the heat exchanger
    I’ve had different people tell me an assortment of different things that
    could be the problem. I think that that transmission cooler is clogged.
    It’s much like the tube in the heat exchanger, only smaller. You can only
    access about 25% of the tubes. I’ve tried flushing it with Salt-away and
    it helped a bit. I think that it needs to be soaked in something
    stronger. Can the transmission cooler be bi-passed without any ill
    effects?
    Bob, I’m in Marion MA today and will be leaving tomorrow, weather
    permitting, and most likely head for Pt. Judith and then west again after
    that. This whole area is new to me, but I don’t like to get too far off of
    the main routes. I could probably be in Stamford by Thursday or Friday.
    Thanks everyone
    Jack Clarke
    Xanadu IV
    Please keep any suggestions coming
    in reply to: alternator belts #78535
    Jack Clarke
    Jack,
    I don’t know if this will help you or not, I just had the alternators
    rebuilt and the belt number that was on the Balmar was “Premium 25-10555”.
    I don’t know what the profile of the belt is and my engine is a Perkins.
    Jack
    Xanadu
    On Tue, May 15, 2012 at 6:26 PM, calicojack wrote:
    Thanks Pete – I have the alternator off. I’ll try the industrial belt
    route. Best/ Jack
    in reply to: galley stove #78522
    Jack Clarke
    You might want to try the Cruisers Forum in the classifieds.
    Jack
    Xanadu
    On Sun, May 13, 2012 at 6:22 PM, quent wrote:
    Try Ebay, Craigslist, and Bacon’s in Annapolis.
    in reply to: sail sheets #78423
    Jack Clarke
    Try. wwwmthebinnacle.com. They are in Halifax but they have free shipping on orders over $100. Always good pricing.
    Jack
    Xanadu
    Sent from my BlackBerry device on the Rogers Wireless Network
    in reply to: Everybody out sailing? #77968
    Jack Clarke
    For anyone that is thinking of traveling to Cuba, check out this web
    site http://www.cubacruising.net it has a lot of useful information.
    Jack
    Xanadu
    On Thu, Nov 10, 2011 at 10:14 AM, Silverheels wrote:
    Very sorry to hear about your friend’s encounter here in The Land of the
    Free, while those terrible Cubans continue to welcome everyone with a
    smile. As for me, I’m a journalist on assignment from a national
    magazine. The Treasury Department can go screw itself. (Sorry, but I get
    a little heated when our government presumes to infringe on our
    freedom.)
    in reply to: Newfound Metal Ports-price with boat show discount #77913
    Jack Clarke
    I ordered my 5 X 12’s two years ago, I installed one last year and started
    to install the remaining six two weeks ago. When I originally placed my
    order, they only had two in stock, I ordered the tinted ones. They shipped
    the remaining four ports to my and it had on the box ” OLD STYLE” and I
    didn’t think to much about it. When I went to install them they only had
    one bolt hole in the top center of the frame and outer ring. I had to drill
    a center hole in the teak trim ring and make a new template. I still have
    to call them about this, but they most likely won’t do anything about it
    now.
    Jack Clarke
    Xanadu
    On Wed, Oct 19, 2011 at 7:48 AM, joe shimkonis wrote:
    List price in 2010-1379 for 6 or 229 each.With boat show discount,shipping
    cost $115,teak frames,screens,the total came to $1800.The teak frames are
    needed because the cabin sides are too thin.
    Also-you should specify what length bolt you need other wise you’ll have to
    cut them.Also includes a template for hole drilling-can be returned for a
    refund.
